SOURCE: grapic not comptbl
Dear Sir,
Please post questions in detail to help us to serve you better. The answer which I'll be providing you is based on assumption on the little data you have provided. you want to play games on your PC but you get an error saying the graphic card is not compatible. Now , I suggest you check the minimum requirements which the game needs is available on your PC? if not, please buy a Graphic card which is compatible to your PC and also suffice the games requirement.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
SOURCE: change the display resolution from 1024x768 to1024X1280
go to control panel > dosplay settings > click on the settings tab > click on the advanced button > c.ick on Monitor and tick the box that states "Hide Modes that this monitor cannot display > click the adapter tab > click on button "List all modes" This will list every resolution your monitor is capable of displaying.
SOURCE: resolution 1024x768 stuck in 8bit color i need
If you are runnineg windowsXP goto control panel by catagory select appearence and things then display, setting, then under color select 32bit, if you are unable to select anythingother than 8 I recommend you go to DELLs website and download display driver for your system.
SOURCE: I am getting an error
Resolution error occurs when the sizes are not met with the display settings, based on your monitor size there must be a default size for the icons to appear normal or regular sized. However it is also important to know what resolution you are on at this time.
