SOURCE: I Need Serial Number for ScanSoft PaperPort Deluxe 9 for PC
download any from >>
http://www.crack.ms/cracks/crack.ms?id=2057420
Do not forget to rate this solution.
Thanks for using FixYa.
SOURCE: Describe your scansoft paperport deluxe 9 windows
Hi there and welcome here
Take a look here :
http://reviews.cnet.com/document-management/scansoft-paperport-deluxe-v/1707-3522_7-30787056.html
It does not describe windows Vista, so I think it is not compatible with windows Vista, so there is 2 thing you can do :
1. you can see if it runs in compatibility mode, and you do it in this way : Highlight the program icon on the desktop or in the start folder, choose properties, select the last tab, choose compatibility mode with windows xp and try to open the program
2. If it is not working maybe you can upgrade to a newer version, for that you have to go to the product homepage . Normally you find a link in the program where you can go to the product homepage.
Hope this can help
Have a nice Christmas over there
Please rate my answer
SOURCE: It will not work with windows 7. Is there
Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all This should all be done in Administrator Mode. & done to BOTH the install .exe and the programs run .exe
SOURCE: why paperport 9 doesnt work on windows 7
Maybe because they're up to 12 and 10 didn't work on Vista?
Just a thought.
If you get on their email list, you'll eventually get to buy the upgrade at half price. $50 for PP12 and $100 for PP12 Professional.
http://nuance.custhelp.com/app/answers/detail/a_id/5775
Carl
SOURCE: Is there a driver download
Can you please elaborate your issue a bit.
What exactly are you trying to achieve with the computer?
Admin
HNetworking.com
