Washing Machines Logo
Posted on Jan 30, 2011
I keep on getting a code on my washing machinge F21 and SUD what does it mean/ once in a while my washer it stops and it show these erro codes what do they mean?
5 Related Answers
Anonymous
  • Posted on Feb 27, 2009
SOURCE: Kenmore Elite HE3T - F21 Error and SUD error
I don't just got done checking and sure enough it was filled with socks, rocks, and small debris. I don't know yet if it fixed it but will know in a few hours. In any case, these items could not have been good. First, try to make sure all water is out. Run on spin cycle for 10 minutes, be prepared for about 4 to 6 cups of water coming out.
the fix: You should always unplug for safety!
There are three screws at the very bottom of washer. You will need and extension and a star tip. They are on good and tight so I used a cordless drill and extension. I'm sorry I can't tell you which star tip I used. I bought a little security kit from harbor freight that has all these tips and one worked. Their is a white canister that has one hose in and another hose out. Just unscrew slowley and clean if dirty. You might be as surprised as I was if you find any junk.
Good Luck
Anonymous
  • 220 Answers
  • Posted on Sep 03, 2009
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Anonymous
  • 6784 Answers
  • Posted on Dec 07, 2009
SOURCE: Sears kenmore washer 110.42822200 error code sud
SUD- Suds lock (Overdose of detergent detected during the wash cycle, or the actual brand is a non HE type)
The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Possible Causes / Procedure
• If too much detergent was used:
A. Run the unit through a Rinse/Spin cycle.
B. Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent. If the problem persist, follow this check list below.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Press PAUSE/CANCEL twice to clear the display.
Anonymous
  • 15935 Answers
  • Posted on Sep 11, 2010
SOURCE: Fault code 5 d - what does that mean and how do I fix it
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • Posted on Nov 29, 2010
SOURCE: Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Top Maytag Washing Machines Experts
jdthefixer
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
