Sony PlayStation Portable (PSP) Console Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm getting the error code 8010850f - Sony PlayStation Portable (PSP) Console
Anonymous
Level 3:
Genius:
  • Master 1,157 Answers
  • Posted on Feb 05, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1157
Questions
Helped
424975
Points
2951
Hi antoniodarri,
It seemslike you can't play games with your PSP. You also mentioned about the error "8010850f". Don't worry you can remove this error by applying the options below andthere's no need to delete anything or need of formatting your PSP.
Option 1: Go to account management by signing in to PSN on your PSP. Once underaccount management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to accountmanagement - activate/deactivate - PSP - games.
After you processed either of the 2 options you can now play your games with nointerruption.
Hope it helps, Thank youfor using FixYa.
When choosing any game I am getting this error "To use this content, you must activate the system. (8010850F)"
Use these intructions to ACTIVATE your console.
It should override the error message.
PCHEPLSTER007 from youtube
tip
PSP ERROR CODE "8010850f"
How to fix error code "8010850f" on your PSP:
Error code "8010850f" sometimes appeared when you downloaded certain games on your PSP. It will requires you to activate the system to use the content and could only work when activated through PSN. Here are some tips and tricks on how to fix this error.
Option 1: Go to account management by signing in to PSN on your PSP. Once under account management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to [Accountmanagement] - [activate/deactivate] - [PSP] - [games].
After you processed either of the 2 options you can now play your games with no interruption.
Hope it helps.
1helpful
Psp error code 8010850f when trying to play demo games
From TIPS section:
Hope it helps.
1helpful
Error 8010850F
Just go to account management>System Activation>Activate Games (or whatever isn't working for you)
5helpful
System 8010850f
I think this is the error that says to use this content you must activate this system. And it doesnt allow you to play demos/games.
For this sign in to PSN on your PSP. Select account management > activation > games and then activate the PSP.
However PSN will still be down in some regions so you may not be able to do this till its back online.
2helpful
Error code 8010850f
Assuming that you are using a PSP Go, then this error is caused by the fact that your device is not authorized to play your games anymore. This sometimes happens after a firmware update. In order to fix the problem, you must either attempt to sign in with the PSN account that you created when you purchased the device, or you must connect the PSP to the computer and use Sony's online PSP management page to reactivate the PSP. Go to: https://store.playstation.com/accounts/manage/cam_psp_activation_select.vm and then follow the on screen steps.
2helpful
Error code on psp 8010850f
the problem you have is not the above the problem you have is with the dodgy update sent out thousands of people all over the world are having the same problem if you go to sony playstation web site you will find out more and sony are working on the fix now and will be sorting out another update to fix this problem with the ps3 update
plz rate this solution as i have a whole page of unrated posts, thanks,,,,
13helpful
2answers
Psp go i have an error code 8010850f it says i
If you are getting this error when trying to play games from memory stick i might have the solution for you.
1) Back up your data on memory stick to PC using usb cable.
2) Format your memory stick from PSP.
3) Copy game from your PS3 to your PSP using usb cable.
4) Copy game saves etc. from your PC back to your PSP.
5) Play your games on PSP.
20helpful
3answers
Psp i have an error code 8010850f it says i must
no need to delete anything all you need to do is go to account management, system activation, then games then you should know what to do from there on out lol
5helpful
2answers
Psp i have an error code 8010850f it says i must activate system whats wrong how do i activate?
Hi vam7576,
With this type of error "8010850f", you really need to activate your PSP. You need to get rid of this error so you can play and use your PSP with no interruption. You can activate your PSP by doing either one of the options below. No files will be deleted during the process and no need to reformat your PSP.
How to remove error
"8010850f":
First Option:
Connect your PSP to your PS3 using a USB. Thengo to account management - activate/deactivate - PSP - games.
Hope it helps,
Thank you for using FixYa.
Best regards,
Reyjoshua07
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Frank Fernandez
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
