Uniden BC340CRS Base Scanner Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I program the channels for a Uniden scanner?
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Feb 03, 2011
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
951049
Points
7371
The best programming instructions are found in the factory manual. You can download and print the manual for the BC340CRS, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
If yours is a different model scanner, let me know and I will try to find the manual for you.
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
5 Related Answers
Anonymous
  • 90 Answers
  • Posted on Sep 26, 2008
SOURCE: Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
Roger Chance
  • Posted on Oct 12, 2008
SOURCE: Programming a scanner
To program a BC 70XLT turn the scanner on and hit the man key.
enter the channel you want to program (ie 1) hit the man key again then enter the frequency you want to scan (IE 450.625) then hit the E key to enter the freq into the location if you want to sequence to the next channel then hit the man key again enter the freq and hit the E key.you can go through all 20 channels this way.
Anonymous
  • 379 Answers
  • Posted on Jan 13, 2009
SOURCE: lost book to scanner its
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
Anonymous
  • 4 Answers
  • Posted on Feb 24, 2009
SOURCE: I have a uniden ubc73xlt handheld scanner,can't
Try a master rest:
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
Anonymous
  • 2761 Answers
  • Posted on Aug 16, 2009
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
How to program channels
The BC60XLT is limited to ten channels. Programming is best described in the factory manual, which you can download and print here:
http://www.uniden.com/pdf/BC60XLTom.pdf
Bill B
2helpful
30 channel 10 band radio scanner uniden 8c60xlt
You listed your question under the BC60XLT, which is a 10-channel scanner. With 30 channels, I'm guessing that yours is actually a BC60XLT-1. To program a known frequency into it:
- Power the scanner ON.
- Press MANUAL.
- Enter the channel number that you wish to program.
- Press MANUAL again. (NOTE: Instead of entering the channel number, you can press MANUAL repeatedly to advance to the desired channel.)
- Enter the frequency, including the decimal point.
- Press E to store the information in memory.
- Repeat the above for other channels.
More detailed information can be found in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
If your scanner is a different model, pleasd let me know.
For a comprehensive database of active frequencies in your area, visit:
Bill B
How to program the frequencies on a uniden bearcat 50 channel 800 mhz radio scanner?
To program the majority of non-trunking Bearcat scanners,\:
- Press MANUAL to stop scanning
- Enter the channel # to program followed by MANUAL (OR just press MANUAL repeatedly to advance to the desired channel).
- Enter the desired frequency, including the decimal point.
- Press E (ENTER)
If these steps don't work with your scanner, please provide your model number and I'll get back to you with specifics.
Bill B
4helpful
How do I program my bearcat 144xl scanner?
The BC144XL is one of the few scanners that I haven't been able to locate a manual for, but programming it is fairly straight forward. Here's some guidance from Uniden:
Here are basic instructions for programming nearly all of the older scanners that Uniden produced. When the scanner is turned on press the MANUAL key, then press the channel number that you want to program first, then the MANUAL key again. This will stop the scanner from scanning and hold it on the channel that you want to program.
Then you enter the frequency (be sure to use the decimal point in the right area when entering in the frequency) and then press the E or ENTER button to save the frequency on the channel. You are now finished programming the channel. To advance to the next channel simply press the MANUAL key and enter your next frequency the same way that you entered it on the previous channel (as described at the beginning of this paragraph).
I hope this helps.
4helpful
How do i program a uniden bc144xl scanner
I couldn't locate a manual for this one, but here's some programming guidance from Uniden:
I hope this helps.
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
Need manual for uniden scanner bc155xl
I couldn't find a manual for this oldie, but here's programming guidance from Uniden:
I hope this helps.
5helpful
How to program and delete uniden bearcat scanner 210 XWneed to c
Need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
22helpful
4answers
Programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Top Uniden Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
Frank Fernandez
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
