Kingston 2GB Secure Digital Memory Card Logo
Posted on Feb 04, 2011
How can i delete the write protection? - Kingston 2GB Secure Digital Memory Card
  • Marvin
    Marvin Feb 04, 2011
    You can't.
Joshua Cox
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Feb 04, 2011
Joshua Cox
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
3446
Points
39
There should be a little slider switch on the card that enables and disables write protection.
3helpful
How to delete protected images
If you want to delete everything on the card, the easiest way is to format the card. This will wipe out all images (and any other data as well) on the card, whether protected or not. The Format command is in the Setup menu. Details on page 32 of the manual.
To delete individual protected pictures, unprotect them first. From the Playback menu select Protect/Unprotect (the key icon). Details on page 84.
3helpful
2answers
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Deleting protected pictures
"Protecting Photographs from Deletion
In full-frame, zoom, and thumbnail playback, the button can be used to protect photographs
from accidental deletion. Protected files can not be deleted using the button or
the Delete option in the playback menu, and have DOS "read-only" status when viewed on
a Windows computer. Note that protected files will be deleted when the memory card is
formatted"
This is from the nikon website. You can down load the entire users manual here:
http://www.nikonusa.com/pdf/manuals/dslr/D40X_en.pdf
If i format the camera, will the labeled protected be erased?
Yes. The format operation will delete all pictures, protected or not. The protection only prevents accidental deletion via the delete button.
4helpful
2answers
I downloaded some pictures to my school computer and now my camera won't take any pictures. Message is Memory card write protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
3helpful
2answers
How can I delete write-protected files in pen drive
my multi-card (SD) kingston 2 GB is unable to copy , delete and format. It is always say that your multi-card is write-protect. I try to delete some file on it. It is able to delete but i reconnect to my PC,it shows my previous deleting files. why? If you have time , help me please.
2helpful
2answers
Deleting protected content
I have a SE K310i. It is the "spiderman3" edition and has a few pictures and a trailer of that movie which are protected( i.e cant be deleted by users like me). delete?
9helpful
Deleting protected files from sony ericsson k310i
i want t delete my protected files such as videos and pictures
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
