I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
33 parts fuel to 1 part oil 100ML QUALITY AIR COOLED 2 STROKE TO 3.3 LITRES (ON THE GAS PUMP) is perfect for least ware and long spark plug life ( I HAVE USED THIS RATIO AND FOUND IT THE BEST FOR 10 PLUS YEARS
SOURCE: homelite whipper snipper is hard to start and its
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Testimonial: "Thanks, will try it!!!"
