Mcafee RETAIL BOXED PRODU MTP08EMB3RUA TOTAL PROTECTION SUB MINI-BOX 3U for PC Logo
Posted on Feb 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It won't install - Mcafee RETAIL BOXED PRODU MTP08EMB3RUA TOTAL PROTECTION SUB MINI-BOX 3U for PC
Anonymous
Level 2:
Novelist:
  • Expert 143 Answers
  • Posted on Apr 05, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
143
Questions
0
Helped
38580
Points
235
# Download McAfee Antivirus:
Click here if you are using Windows 7, Windows Vista, or Windows XP .
# Click on Run.
# When the download is complete, the installer will begin preparing itself.
# Begin the installation by clicking "Next".
# Select the appropriate License Expiry Type (in the drop down menu in the upper left of the window). Then select the button for "I accept the terms..." and click OK.
# If you already have McAfee Antivirus installed, you may see this screen. Just # click OK and the installer wizard will import your old settings into the new version of McAfee.
# For Setup, type Next
# The Wizard will now begin installing the files. It may pause the installation process and ask you to end particular applications so that it can safely continue the installation.
After a successful installation, McAfee will ask if you want to update the virus definitions and run a scan; you should do both.
Once installation is complete, McAfee will automatically update the virus definitions. Once the updates are finished click Close.
Install McAfee
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
My dryer had a broken belt so I installed a new one. According to the directions I could find online, it said to install the belt with the smooth side against the drum. Now that the belt is installed the...
If you have the belt down in the groove on the tub it won't work. The belt slick side goes to the drum and goes back like this:
I recently worked on one of these and took photos of the repair:
http://appliancejunk.blogspot.com/2011/09/old-maytag-dryer-belt-replacement.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
My laptop won't connect to youtube for some reason even though it is connected to the dongle it still won't connect to youtube. can you please give me a solution to this or at least tell me why...
Hi
Please check you install the abobe flash player, if not install the install the latest flash player and try again otherwise please send me the your " Error"
My computer won't recognise or let me install adobe. It also won't let me install plug-ins
there will be chekbox /don't remaind me again/, chek it and ok. In your pc th newest version of adob , and the old plugin can not install on it.
Won,t print
are all the drivers installed correctly? when you try printing off microsoft word (ctrl +p) try viewing the properties
good luck
Jayce
Top Mcafee Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Mcafee Computer and Internet Expert? Answer questions, earn points and help others
