Washing Machines Logo
Posted on Feb 14, 2011
How to replace NTC Temp sensor on Hoover HNL 662 Washing Machine ?
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jun 05, 2008
SOURCE: hoover nextra hnl 2126 washing machine
Click on your model number (below FIXYA) on this website, & search for your model, make. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is.................
Rate me pl if helped...................
Anonymous
  • 188 Answers
  • Posted on Mar 01, 2009
SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Anonymous
  • 1036 Answers
  • Posted on Sep 30, 2009
SOURCE: Hoover HNL 6166 6kg A+AA 1600 washing
Hi.
It is very likely you need to replace the motor brushes. These are the electrical conections in the motor that wear after a time. They are fairly cheap, uses-replaceable, and available from online appliance specialists.
Turn off water and unplug before removing top/ back pannel to access motor. ***** CHECK MOTOR TYPE BEFORE ORDERING PARTS ******
Anonymous
  • 3 Answers
  • Posted on Nov 05, 2009
SOURCE: my hoover washing machine wont spin and is full of
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Anonymous
  • 3 Answers
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Top Hoover Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
