Unsure which ABC school you are inquiring about, but since many questions come from South Africa on this web site, which is operated from California, in the United States, it is necessary to assume Pretoria, or Johannesburg for miscellaneous questions without sufficient information to answer.
The ABC Primary School in Pretoria, South Africa is registered.
The placement of both your questions in the Retail Supplies category is confusing.
ABC NURSERY / PRIMARY SCHOOL
381 Rose Etta Street
Pretoria West
(012) 327-4274
Scroll through your contacts list, when you get to thet number in question, select details > contact name > assign tone > then select your ring tone and assign it to the contact.
For the text messaging, you are on predictive text input, and the upper left of your screen would have an UNDERLINED pen with either 'abc', Abc' or 'ABC'. Toggle your hash key until you get any of the UN-UNDERLINED pen with 'abc', Abc' or 'ABC'.
To disable the dictionary in your text panel, while in create message mode, select 'options', then 'dictionary', then 'dictionary off'. That should turn off your dictionary mode. Alternatively, while in the text mode, at the top left corner of the screen, you would see 'Abc' or 'abc' or 'ABC', with an underline mark. Toggle your hash key (#) till you see an 'Abc', 'ABC', or 'abc' without the underline. Then your dictionary mode would be off.
You need to press the number key # briefly to switch between the abc, Abc, ABC, T9 abc, T9 Abc , T9 ABC and 123. The Status indicator in the top of line display. If you press and hold all input modes will be displayed.
While in text you should be able to hit hash key and at the top right hand corner see it change from abc (no pre) 123, abc Pre, &, if you select just abc, it should be off.
Predictive should be abc with a little square next to it.
steps to send theme via bluetooth:
1. change the extension of the theme(eg abc.nth to abc.mp3)
2. send that to ur cell
3. rename the file to original one (abc.mp3 to abc.nth)
Install file explorer that will be helpful
click on this link
http://www.sharejar.com/javasoftware/2469/File_Explorer-31750.jar
regards
Mohit
