Black & Decker String Trimmer Cordless 12" 18V Logo
Posted on Jul 25, 2008
I have a problem with the feed on a B&D trimmer
  • ofriends Jul 27, 2008
    My string won't STOP feeding. Too much keeps feeding out and eventually wrapping around the shaft. I've taken it apart several times and it just won't stop doing it! VERY frustrating!
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 30, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
4255
Points
18
Your spool is eather in up side down or backword
Auto feed doesn't work
Take the end apart and make sure the line is not getting bound up or is not over filled to where it can not move freely
Need instructions on changing the spool on electric grass trimmer/edger
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
1helpful
After going through at least 3 string-type lawn trimmers, I have yet to find one that can actually feed the string. I have used Black & Decker, and most recently, Toro 8" cordless, with the same...
This can and is a frustrating problem. Some things that help are to be sure to use the right size of trimmer line. Be careful when rewinding the reel to not twist and cross the lines. I realize we should not have to give this much attention to it, but until somebody "builds a better mousetrap", we only have so much to work with.
10helpful
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
1helpful
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
10helpful
2answers
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
Top Black & Decker Garden Experts
Sudeep Chatterjee
Sudeep Chatterjee
Steve Sweetleaf
Steve Sweetleaf
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
