SOURCE: I Have UPS 700-6000VA. It keeps changing on
Bypass not available is a common alarm.
This is because the input and ouput parameters
volts and frequency do not match, suggest checking these with meter or using ups sw and comp.
Bypass will not function if either v or f is incorrect, check manual for specs.
Post more info about batt on load with mains conected please, as this could mean major fault such as rectifier failure or micro malfunction
Hope this helps, thanks for asking FixYa
SOURCE: we usd powercom ups 6000va
Does the UPS work when A/C voltage is present, if yes remove the battery, confirm that the battery can retain charges by using external load with a multimeter to get a steady 12V for about 30 sec before the voltage starts to drop. If the battery does not retain charges, replace the battery. However, Not that when you open the UPS your are exposed to life Voltages and run a great risk of electric shocks. Experienced technicians are expected to work on this kind of equipment.
SOURCE: I have Sandisk USB 4G
which OS u r using? XP,Vista and 7 Os will automatically install the drivers for it.
if not, check sandisk site for drivers
SOURCE: My desktop 600w (not true rated) PSU sadly passed
This WEB site give you the UPS information you are after.
http://www.hardwareanalysis.com/content/topic/42774/
