Texas Instruments TI-30XA Calculator Logo
A
Anonymous Posted on Mar 03, 2011
How do I get the variance on the calc. - Texas Instruments TI-30XA Calculator
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
194
Points
The following is an example for the dataset {5,7,18}. This will generalize to any dataset that you would like to use.
  1. Enter your datapoints:
    Press "5", "SIGMA+", "7", "SIGMA+", "1", "8", "SIGMA+"
  2. Calculate the standard deviation
    Press "2nd", "sigma_(x n-1)"
  3. Square the standard deviation to get the varience:
    Press "x^2"
    If you followed the correct steps you should see "49" as your answer.
My Compaq Presario CQ56 has calculator that keeps popping up when I press the arrow keys or the numerical keys. Please help!!
Well what I really wanted to know the most is if it pops up while you\'re not even touching your mouse or keyboard...
If you changed your .exe to .com like I said and it came back, then it\'s normal... ... Just delete the calc.com file. Don\'t worry, calc.exe came back on its own so the calc.com we made is now useless. That\'s why you can now delete calc.com. It\'s also just to reset what was in your old calc.exe, in case it has a keyboard shortcut and other hidden stuff integrated.
Still gotta make sure though... Can you right-click on calc.exe and choose "Properties" to see if there\'s any keyboard shortcut? The field (shortcut key) should be left blank in case there\'s something in there. Or to "None".
IF the calc.exe still pops up while you\'re not doing anything, then it\'s time for some hijackthis.
Get it here:
http://www.download.com/Trend-Micro-Hijack...4-10227353.html
Do a system scan and save a logfile.
After the scan is over, copy all what\'s in the list (notepad), and post it here.
Let\'s take a look at what\'s running.
1helpful
Sample variance on Sharp EL-738
To calculate this you press ALPHA (the green key) and 5 or 6 depending on if you want sample variance (ALPHA 5) and for population variance (ALPHA 6).
1helpful
2answers
Hello. I just wanted to ask you how do I calculate the variance and standard deviation in my cfx9850GB plus. I had a quick look at the manual but I couldnt find the info. thankz .
This shows you how to enter your data and calculate some statistical values. Keep in mind that the variance is the square of the standard deviation.
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the statistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Example: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
How do i use this calculator (casio CFX 9850)to find the variance
Part A shows you how to enter your data and calculate some statistical values. Keep in mind that the variance is the square of the standard deviation.
You can safely ignore the PART about REGRESSIONs until that time you need the information.
PART A
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
x bar =74.7142857
n = 7
minX =56
Q1=68
Med =75
Q3=85
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
PART B
  1. Once you enter your data [MENU][STAT],
  2. press [F1:Graph],
  3. select Gph1, Gph2, or Gph3.
  4. Once the graph of the experimental data is drawn, you will have access to the diverse regression models.
  5. Your choices are
  • [X:Linear]
  • [Med-Med],
  • [Quadratic :X^2]
  • [Cubic;X^3]
  • [Quartic: X^2].
  • Press [F6] to scroll right to access the others:
  • [Logarithmic:LOG],
  • [Exponential :EXP],
  • [Power :Pwr] and
  • [Sinusoidal:Sin]
  1. After you select a model and press [EXE], the screen displays the equation and its various coefficients.
  2. On that same screen, you have a menu option [F6:Draw].
  3. If you select it, the regression curve will be drawn on the same screen as your statistical graph.
  4. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
  5. The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
Lost CALCULATOR application
  • Scientific
  • Statistical
  • Financial
  • Programmable
  • Graphing
  • Complex arithmetic
  • Matrix/vector arithmetic
  • Unit arithmetic
  • RPN
Download You can download Calc into your phone or MIDP device using one of these links:
Calculator 1
http://midp-calc.sf.net/Calc.jad, or
http://midp-calc.sf.net/Calc.jar
click her for calculator 2
transfer both the files to your mobile and then install them by just clicking on open install
I am java beginner and I want a help in writing a java program to calculate the variance for an array of numbers
the best thing to do here is to separate the steps for calculating the variance into different functions. To compute the variance the first thing to do is to compute the mean or the average of the numbers in the array. so your first function will loop through each of the numbers and divide it by the length of your array. the output is the returned. The next thing to do is create another function for the variance. loop through each of the numbers again and subtract to each number the mean. square the value then add to the previous. so that means you have another variable that starts from zero and just adds the answer. after that divide it by the length of the array again and what you are going to get is the value for the variance.
21helpful
3answers
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
How to compute varience & std deviation on calc..
Get instruction booklet which gives key strokes and examples on pages 10-11
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18#27
1helpful
2answers
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Top Texas Instruments Office Equipment & Supplies Experts
Rommel Balcita
Paul Bade
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
