Philips GOGEAR SA6045 MP3 Player Logo
Posted on Mar 03, 2011
Database error - Philips GOGEAR SA6045 MP3 Player
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
94
Points
You have to download the updated version of the Philips Device Manager from www.usasupport.philips.com
Once you have downloaded the latest version, run the "Update" function in the Device Manager, and it will upgrade your player's firmware. It will solve most DB corruption issues.
2answers
Toshiba e-studio 356SE error code f 121 Database abnormality user information management database
user management database is corrupted.
Delete the log in the following procedure:[5] + [C] +
[POWER] ? 4. Initialize database ? 1. LDAP database
(to delete user database) (Note that all user, role, group
and accounting data will be deleted.)
If the error is not recovered, reinstall the system software.
([4] + [9] + [POWER] -> 4. System Software(HD data))
Toshiba e 233 is database ptoblem error code F120 how to clear
Database abnormality: Database is not operating normally.
(1) Rebuild the databases. (Perform 08-684.)
(2) If the error is not recovered, initialize the HDD. (Key in "2" at
08-690.)
Database Error show on screen Navigation database
Contact me directly, my e-mail: service@gps.pol.pl
2answers
When I trying to open the archive files, error "RRV Bucket is corrupted" is displayed. I am unable to solve this problem. can you please provide a solution. I understand data can be retrieved ,...
If this error occurs in a case where Shared Mail is being used, then first refer to the documents titled "'RRV Buffer Overflow' Error Message While Attempting to View a Mail Document" (#1093390) and "Using the OBJECT COLLECT Server Task to Manage Shared Mail Databases" (#1088860).
If the database is not in R5 format (ODS 41), then from a Domino 4.x server run Compact -M on the database. On a Domino 5.x server simply run Compact on the database. If updating the ODS to 41 does not resolve the issue, refer to the document titled "Database Has Grown too Large; Use File New Replica...' Error Occurs When Opening Local Database" (#1102305).
If none of the above resolves the issue, then where possible, a new replica should be made. If a replica is not available, restore the database from a backup, if one exists.
Supporting Information:
Corruption can be caused by many things, but a possible cause for the error in this case was that a third-party application had altered the physical location of the database on the hard disk, resulting in the Record Relocation Vector table being incorrect and the information not being located. This has been reported to happen with customers using a disk defragment utility while Compact is running.
4answers
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
Keperksy Internet 2009: Error message:
try to update your kaspesky online to resolve the database corrupt error.....usually this error occurs whenever you restore your pc to a previous date that make your database corrupted...goodluck
12helpful
4answers
Error 3343 when I start PC Charge, how can I fix this?
error 3343 is a database error. Unfortunately, PCCharge is still in the stone-ages of computer technology and they think VB6.0 and MS Access 2.0 are stable and secure ... At any rate. 3343 is simply an unrecognizable database, in this case due to corruption. There is a program in the PCCharge directory called VisData. This will allow you to run a repair and compact the database. To use:
First make a backup of your PCCW.MDB database in your PCCharge directory (C:\Program Files\Active-Charge (PaymentServer); C:\Program
Files\PCCW (PRO)).
Execute VISDATA.exe.
File -> Repair MDB.
Select the PCCW.MDB database from your PCCharge directory.
Select 'No" to open Repaired Database.
File -> Compact MDB ... 2.0 MDB
Again, Select the PCCW.MDB
It will then prompt for what you want the database to be named. Simply select PCCW.MDB again, select 'YES' to replace existing database.
Select 'NO' to encrypt database.
Select 'NO' to Open Compacted database
Exit Visdata and start PCCharge.
It would also be a good idea to go ahead and update to the latest available Scripting Runtime library. This can be found by going to microsoft.com and searching for the phrase 'windows script'. (To my knowledge, 5.7 is the latest version).
Record insertion filure in database
First check the data against the database field definitions to make sure you are not violating the database schema.
Second, find a Database Management Systems expert that is in charge of your database (if one exists) and ask them.
Third, try finding the error in the database manual.
Fourth, go to the web site for the company that produces the database and use their search engine to locate the error.
One of these should work.
Top Philips Audio Players & Recorders Experts
SmartAviator
SmartAviator
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
