Canon PowerShot G9 Digital Camera Logo
Posted on Mar 19, 2011
E16 - Canon PowerShot G9 Digital Camera
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Oct 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
1359
Points
35
That's probably some sort of error code your camera is displaying. I know the most common codes are E18 and E24 on canons, for the E16 try going to the following website and emailing them: www.camerasandparts.com They just work on the canons and I'm sure they've dealt with this problem before. If you end up needing to have it serviced, that site is wonderful and about half the cost of what canon charges, plus they do amazing work on these powershot cameras.
E16 ON DISPLAY FLASHING
The e16 error code indicates that there is a problem with the machines door lock.
MY FRIGIDAIRE DRYER STOPS AND THE DISPLAY READS E16
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
2helpful
2answers
Canon mp250 error code e16
How to Reset waste ink counter (Error E16)
1. Unplug power and USB cable.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Hope it helps.
2helpful
What is symbol of e16 means??
Error E16 mean commonly you cartridge must be reset (something Runout), press for 5-15 second for reseting each of cartriedge.
11helpful
3answers
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
24helpful
2answers
E16 error message for for canon pixma 210
E16 must be "Ink remaining unknown".Press and hold the "resume" button for 5 seconds.
E16-e19
E16 says that remaining ink is unknown, E19 is empty. You can press resume to print, but you should replace the ink.
84helpful
9answers
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
6helpful
3answers
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Top Canon Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
