Go to messages and to the left it says "inbox" and to the right it should say one of the following....Received, message type, subject or from. click on that... Then choose one of the options..
RECEIVED: Let's you sort the messages by the date you received them either last ones first or new ones first. To change which order you just have to hit received twice. Then scroll up to the top with the bar to the right.
FROM: Let's you sort messages by the sender. For example all "tony's" messages will be together and all "sally's" messages will be together.
SUBJECT: It will sort your messages according to what they say. For example if you have two messages that start with "I'm not home" they will be grouped together. It puts all the messages in alphabetical order no matter the date time or sender,
MESSAGE TYPE; Ok this one is a little tricky. This one sorts your picture messages together, your sim messages together and regular text messages together. They may be in alphabetical order too.
Now if you would like your newest messages first this is what you can do. Hit received and make sure your at the top of your messages (if not scroll up) and if the newest message is the first one there. Your all set. If not repeat the process and then scroll up (assuming you have a lot of texts). Let me know if I helped!
