This clock radio features a dual alarm system, with two separate alarms that can be
operated independently. The alarms can be set to wake two people at different times, or
to have a main alarm and a backup. One alarm features your choice of radio stations as
an alarm wake sound, while the second features a buzzer wake sound. You can set the
radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator
will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the
"alarm Set Button again.
2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold
a button for a few seconds to advance the time rapidly. Be sure to set the correct
AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station to wake up to.
First, press the "AM/FM" Button to select a radio frequency. Next, select a station
using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level.
4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2
setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the
weekend. Before setting the alarm, be sure that the correct date is set.
5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press
the "Alarm Set" Button twice so that the display shows the standard, non-flashing
display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm
Indicator will appear.
2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as
described above.
3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer.
4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set"
Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio
Alarm Indicator appears on the display. As long as this indicator appears, the alarm
will sound at the set time and days.
2. To activate the buzzer alarm, press the
"Buzzer Alarm" Button so that the Buzzer
3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still
maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its
7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on
the display.
4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm
sounds. The alarm will shut off for approximately nine minutes before sounding again.
The feature can be repeated several times during the one-hour snooze cycle.
5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an
Alarm Indicator appears on the display, the alarm will sound at the set time, according
to the 7-5-2 settings.
