Maria Ulloa Posted on Mar 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have forgot the combination. How can I open my briefcase?
jessica GARRETT
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 31, 2014
jessica GARRETT
Contributor
Level 1:
Answers
Questions
0
Helped
307
Points
0
Forgot code on my briefcase can't open it
Anonymous
Level 3:
Genius:
  • Master 1,218 Answers
  • Posted on Mar 29, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1218
Questions
0
Helped
295182
Points
1893
Don't know how to help with a suitcase problem...I can help with FAX problems.
Forgot my 3-digit combination for my briefcase
Unless your camera is inside, this is not a relevant question in a Photography forum
How can i open my old samsonite briefcase combination unknown
1. Pull the sliding side latch to the side,
as you would if you were opening the briefcase normally. Holding the latch in position, lightly roll your fingers
down over each numbered wheel to identify which one is the tightest. The tightest wheel will give the least when
you gently tug on it with your fingertip.
2. Set the tightest wheel to "0." Check the tightness of the other two wheels; if they still feel loose, click the zeroed lock to "1" and feel the other two wheels again. Keep going in this fashion until one of the other two wheels feels tight. When one of the other wheels becomes tight, the first wheel is set at the correct number.
3. Move on to the second tightened wheel, continuing to hold the side latch in place. Set it at "0" and check the final loose wheel. Keep adjusting the second wheel, as you did with the first until the third wheel feels tight.
4. Set the final wheel at "0" and adjust it until the briefcase's top latches pop open. Make sure the sliding side latch is still being held in place.
5. Reset the combination to numbers you'll remember in the future. Write them down and store them in a safe place, just in case.
Where can I get briefcase combination lock?
Look for my tip on unlocking luggage with combination locks.
Fix my briefcase combination lock
Use Combination To Release Button--Factory is 00
1helpful
Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
How to Change the Lock Combination on Briefcase
Forgot the combination code !!! for my Samsonite Briefcase. How do I reset?
Dyno....mite!!
If it were as simple as a 'reset"...what would be the point of a combination lock?Seriously?
I need to reset my combination on a pilot leather case
This is how you generally change the combo on a briefcase
1. With the briefcase closed put int the combination
2. Slide the bottons in the opposite direction than you usally do to open it.
3. Now set your new password.
4. Slide the buttons back into place.
5. If it dosent work the first time try it a few times
6. If it fails try reposting with more specific model information about your briefcase
How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • 3helpful
    I need to put a new combination on my briefcase. It has one combination in the middle
    When you open the briefcase on the inside to the right of where the combination is in the center there is a metal lever sticking out.
    Push this lever to the left and hold it there while you change the combination numbers.
    When you let the lever spring back to it's normal position, the numbers set will be the new combination.
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
