Pull the fridge out, use a level to determine how much you need to raise the back (hold level so bubble is centered, measure from bottom of level to floor.) If there is no adjustment on the back get a piece of wood the thickness of your measurement, place in the back of fridge opening, push in and tip up back to place it on wood. If there is adjustment on the back, use the measurement to adjust that much before putting it back in place. You got something cold to drink in that fridge? Have a cold one, good job! countrycurt0
jasonand brig , if you don't have a level, there's another way to determine when the fridge is level. Put a bowl of water inside, fill it up. If the fridge is level, the water will be even all around the edge of the bowl. If it's uneven, make adjustments with shims(they are taper cut pieces of wood used by carpenters, available for a couple of bucks at any home depot, lowes, any buuilding supply store) Adjust the shims until the water in the bowl is even all the way around. Countrycurt0
