SOURCE: Bausch and Lomb rubber eye cups
Bausch & Lomb was purchased by Bushnell in the 70's. Your elites are Japanese made and considered quite a good binocular. Bushnell continued to make the same binoculars bearing the Elite name but replaced B&L with Bushnell. The current elites are different shaped. You could contact Bushnell or you could go to a store in your area that may stock the older Bushnell Elites and try and see if the eyecups fit.
SOURCE: I have a Swift Holiday
There is no real reason why they couldn't be effectively recovered. They would need to be completely disassembled and cleaned in Alcohol, (Keep it away from any plastic/rubber parts though) parts re-lubed where necessary and reassembled after it had been dried and cleaned up.
SOURCE: Have lost rubber eye piece off Steiner binoculars.
need the rubber eye piece for 7x 50 jason/empire binoculars and also the one steel rim that goes under the eyepiece. I would appreciate any help that you could give me. thanks
SOURCE: I have an old tasco 7x-15x35 zoom binocular.
Measure the diameter needed and then check bicycle inner tube diameters. Cut a short section, roll a quarter-inch inside-out, slip over the eyepiece, roll the other end inside-out to form a nice soft shoulder. Costs nearly nothing, works dandy.
