VeriFone PINPad 1000SE Network Terminal Logo
Posted on Apr 12, 2011
Error initializing pinpad Error : 0 Verifone pinpad 1000se
3 Related Answers
A
Anonymous
  • Posted on Jul 02, 2008
SOURCE: Microsoft Retail managment system
You need to have the correct keys loaded into the pinpad. If you got the pinpad from some place other than from your processor, you are out of luck. They will only load the keys when the pinpad is physically in their possession.
Anonymous
  • 10 Answers
  • Posted on Jul 29, 2011
SOURCE: plugged new pinpad 1000se into
The terminal has a setting to tell it whether to use the external or internal pinpad. Yours is still set for internal. Call your merchant services provider and they will change the pinpad setting so that you can use the external PP100SE.
Anonymous
  • 59 Answers
  • Posted on Oct 04, 2011
SOURCE: VeriFone Pinpad 1000se - it has "Tampered Device -
if the intrenal battery is bad you will also get a tamper error, battery needs to be replaced and reload or inject encryption.
How to resolve verifone pinpad sc 5000 errors
what type of errors? most pinpad errors deal with encryption issues. if you have power cycled the terminal and the pinpad and the issue still arises it is most likely encryption.
Veriphone "Bad mac"
is your verifone you are talking about is a pinpad 1000se or the creditcard machine (VX510, VX570 etc.) and bad MAC (message authentication code) and i believe if the machine is not encrypted right or the encryption was errased for some reason, bad mac will appear. I've seen some of bad mac error together with tamper error on VerifonePinpad because the battery is going bad. Replaced battery and load the encryption, pinpad works again. Hope this will help you or call (775)358-2922 look for randy and maybe we can help you further. thanks
2answers
Gettin no Dkey error
your pinpad probably not loaded with the right encryption. call your processor. thanks
Plugged new pinpad 1000se into my verifone vx570 according to instructions. Pinpad shows the moving arrow to indicate it is on. When I run a debit, it does not switch over to accept the customer's pin...
3helpful
2answers
VeriFone Pinpad 1000se - it has "Tampered Device - Press any key" error message. How do I reset this so it will work?
I need a Vista driver - the XP driver won't install under Vista
Check for the driver on the make and model's web site, not the windows...you should find what you are looking for.
2answers
Verifone 1000 se
The Verifone 1000se uses a special serial cable that also has to provide power to the device. It does not use either ethernet nor usb.
2answers
Top VeriFone Computers & Internet Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
