Televison & Video Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the code for apex tv for rc65 direct tv remote
Robert Kitaji
Level 3:
President:
  • Master 1,335 Answers
  • Posted on Apr 19, 2011
Robert Kitaji
Master
Level 3:
President:
Answers
1335
Questions
Helped
450270
Points
4245
There is no setup code indicated for your product.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Let me know if you have any more questions. Thanks.
2helpful
NEED CODE FOR APEX TV TO USE A UNIVERSAL REMOTE(DIRECT TV)
Hello
Remote codes for Apex tV with Direct tv RC-32 model remote control are:
10156, 10748, 10765,
10767, 10879
OK.
tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
tip
DirectTV RC65 Remote Manual
Tivo DirectTV RC65 Remote Control Manual
Have you lost your TIVO Direct TV RC65 Remote Control Manual?
Would you like a digital, searchable, pdf version for reference on your computer?
The TIVO Direct TV RC65 Remote Control Manual is available for download here.
In it, you will explanations of is buttons and features, and directions for setting the remote up for use as a Universal Remote, controlling all your other AV components.
Directions for entering DVR programming codes are here.
Instructions for using the RC65 Code Search function to find remote codes are here.
I hope that helps.
3helpful
2answers
Need the code for a 42 inch LCD TV model ELDTW422 to program our Direct TV remote so it works with the new TV
May I get the madel # of the direct tv remote to help you more. Is it the RC65 or another model
Looking for the direct tv RC65R remote control code for the RCA LX40FHD41YX9 HDTV
RCA TV codes for the DirectTV RC65 are:
11547, 11447, 10047, 10051, 10093, 12187, 12002, 11958, 11953, 11948, 11922, 11919, 11917, 11781, 11347, 11247, 11147, 11047, 10774, 10747,
10679, 10278, 10174, 10135, 10090, 10038, 10029, & 10018.
Instructions for entering the codes are here.
Instructions for searching for the proper code instead of trolling through that list are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
3helpful
I need a universal remote code for an Emerson LC320EMXF Television for a Direct TV remote contro.
You might need to get the RC65 direcTV remote control, you can find them on e-bay relatively cheap, other that that i got mine to work with the code 11864!!
RC65 won't connect to TV or Blue Ray
Instructions for Code Searching with your RC65 are here.
I hope that helps.
6helpful
Direct Tv remote, no response...
TRY CODE 11531 FOR DIRECTV. WORKS FINE WITH MINE
51helpful
5answers
Code for apex tv through philips universal remote
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
Top Directv Televison & Video Experts
Herb Box
Herb Box
Ngoro
john h
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
