Jamo A 305 Main / Stereo Speaker Logo
Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have bought an optical fibre cable to connect from my jamo a305 to my new sony nx810 tv and im getting a buzzing sound, there are 2 optical fibre outputs on the back of the amp, which one do i connect it to? I have changed the settings via the menu to optical fibre cable but still no sound and just buzzing. If you could tell me what ive done wrong that would be great.
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on May 02, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2825283
Points
24829
Have you looked at the manuals?
http://www.retrevo.com/search?q=sony+nx810
A TV won't run external speakers directly. Besides, the TV-related audio should originate at, say, the cable Box, and go straight to your (presumed) AV receiver for the best possible decoding and reproduction.
Buzzing is an analog phenomenon and is NOT carried by optical cable in any case.
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still buzzes with no cables or anything external attached there's an internal problem.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Reverse the cables Left to Right to see if it stays with the cable or the input channel. Follow it back to the source, isolating in the same manner. Eventually you will find the entrance point of the hum. Frequently a cable's ground will oxidize over time and simply removing and reattaching the cable with a twisting motion will re-establish the shield.
Top Jamo Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
