Dryers Logo
Posted on May 02, 2011
How can i get the wiring diagram for the tricity bendix TM540 tumble dryer
5 Related Answers
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: TUMBLE DRYER NO HEAT
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 14, 2008
SOURCE: tricity Bendix tumble dryer Tm540
More likely to be heater element failure, you need to test element and or stat(s) with a meter.
Plz rate this solution
Anonymous
  • 525 Answers
  • Posted on Aug 31, 2009
SOURCE: belt route on tricity bendix 310 w tumble dryer
These links should help out.
http://www.affordableappliance.com/Tips/beltdiagrams.htm
http://www.affordableappliance.com/helpful.htm
Anonymous
  • 57 Answers
  • Posted on Oct 10, 2009
SOURCE: tumble dryer spins, but doesn't heat up
You need an ohm meter to do needed checks. Unplug dryer from power,,, then look for sensors and locate the heat coils. Using the ohm meter, check each device by connecting meter to the posts ( your looking for an open curcuit) Note that when you touch the leads of the ohm meter together, the gage will move? This is closed condition, and if the needle did not move, this is called "open". When you find a sensor or heat coil that reads open, that part is bad.
Now make sure there is not a tripped breaker in the fuse panel of the house,,, because even though the dryer is 220 volt,,, 110 volt runs the tumble motor while the other 110 volt curcuit runs the heat side ( so one will work without the other)
Howard Galley
  • 197 Answers
  • Posted on Nov 09, 2009
SOURCE: tumble dryer running but not heating up
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Tricity Bendix tumble dryer TM 560 will not Heating but drum is rotating.
Hi, it could be the heating element needs to be replaced, best get it checked.
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
2answers
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
Apr 19, 2010 • Dryers
9helpful
Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Tumble dryer running but not heating up its a tricity bendix tm 545
Tricity Bendix tumble dryer Tm540
Top Tricity Bendix Dryers Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Timon Gr?nlund
Timon Gr?nlund
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
