Ovens Logo
Posted on May 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting error code F7 - GE Ovens
ZJ Limited
Level 3:
  • GE Master 17,989 Answers
  • Posted on May 26, 2011
ZJ Limited
GE Master
Level 3:
Answers
17989
Questions
0
Helped
14652161
Points
60866
Microwave will not operate (cook). F7 error code appears on the display. Electrical circuit interruption between L1 and Neutral in the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves the problem
A. Check the Cooling Fan for proper operation or blockage
B. Check the resistance of the magnetron thermostat. It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter is properly connected to plug P2 on the display PCB & Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W inverter.
8. If problem persists, replace control assembly.
Additionally, check this article: oven-error-code-f7-and-how-to-fix-it
Hope this helps.
Anonymous
Level 3:
Genius:
  • Master 1,622 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1622
Questions
Helped
397862
Points
4742
Hi,one of the most common problems with GE electric built in ovens is the error code "F7′ shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link http://www.appliancepartspros.com/ then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the "search" button and in the new window type the word "control panel" in the "search by keyword" box and click the "search" button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business.
Hope it helped..
2answers
Code F7 flashes, after a few minutes, when oven is set at 400 in convection bake mode.
Question edited for clarity and all the typos.
All questions need 'make model (what it is)' as first 3 words.
Generic advice on a generic F7 Oven Error code.
F7 error code can be a result of a faulty wire harness (short-circuit), defective heating elements or oven sensor. A qualified service technician will need to have a look, determine faulty part then replace or repair it.
Apr 27, 2023
Help library: Electric Range: "F-7" error code - troubleshooting
https://www.google.com/search?q=Oven+Error+Code+F7
Oct 06, 2023 • Ovens
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 • Ovens
I am getting an F2, then an F5 followed by sometimes an f7 error code and inconstant temps.
the f 2 code is ( oven too hot ) the f 5 ( watchdog circuits disagree / and f7 ( function key shorted or stuck button .. / the clock ( erc ) may have a warped face . ..I would first replace the tempt sensor in oven . if you still have problem repl clock. and problem over .. thank mm ..
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
2helpful
2answers
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
3helpful
2answers
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
1helpful
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 • Ovens
1helpful
1helpful
F1 Error Code
try fix at http://www.fixya.com/howto/h155060-dreaded_f7_error
this is a common error and easily fixed
Top GE Ovens Experts
Paul Bade
Paul Carew
Are you a GE Oven Expert? Answer questions, earn points and help others
