Maytag MMV5207A Microwave Oven Logo
Posted on Oct 05, 2017
I was using the timer on my microwave #mmv5207AAB to time something I was cooking. Before the time was up it just stopped & now nothing works, controls, light, nothing. I checked the breaker & it wasn't thrown & I checked the plug & there is power. I removed the stirrer cover & there are no brown or rust spots. Can you help?
5 Related Answers
chrisheato
  • 3 Answers
  • Posted on May 01, 2008
SOURCE: intermittant heating
You probably have a new unit by now. The Magnetron part inside usually is the problem with this Maytag unit.I have had this unit blow the 'Magnetron' four times ! Everything else works fine. After watching the technician, I replaced it myself the other 3 times. The whole unit has to come out of the wall to do this. This High Voltage part is dangerous. The part costs about $100.00 from an online parts store. Partselect.com- or someone else.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 09, 2009
SOURCE: Is there a reset button
You should be able to download your owner's manual here.
If not, then I would suggest downloading a few whose model numbers are close to yours to see if they are similar.
Otherwise, you can contact customer service via the links on that page.
Anonymous
  • 1489 Answers
  • Posted on May 03, 2009
SOURCE: my microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
Anonymous
  • 38 Answers
  • Posted on Jul 26, 2009
SOURCE: what causes rust on the inside ceiling of a
Any chemical that is corrosive can cause this, so yes it could be from drugs. Discard right away.
Ottoniel
  • 202 Answers
  • Posted on Aug 05, 2009
SOURCE: Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Top Maytag Microwave Ovens Experts
Paul Bade
Rommel Balcita
vince
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
