Krups is among one of the foremost names in coffeemakers, espresso
machines, blenders and toaster ovens. Krups also makes coffee bean
grinders, such as the Krups 203a. This portable, plug-in grinder has a
removable lid and bean grinder chamber. The blade on the Krups bean
grinder is fastened to the bottom of the grinder chamber. You may need
to replace the blade on your Krups 203. The Krups 203 comes with a
limited 1-year warranty, but the company recommends you send your
grinder to the company to make repairs. Order replacement parts for your
grinder by calling the Krups customer service department at
1-800-526-5377.
Things You'll Need
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
my grinder is moving very slowly as if some thing is stuck.how to make it move.i cleaned it thoroughly.
I just found a MUCH easier way to remove the blade on a Krups F203. On the underside of the grinder, simply remove the sticker with the model and serial#s. You will find an open slot shaped hole for a regular screwdriver. Insert screwdriver and turn the blade counter clockwise against the force of the screwdriver. The blade comes right off. I sharpened the correct edges with a file, and reinstalled the blade. 10 minutes. Put the sticker back in place.
Thanks for the directions but the plastic nut is fused to the threads and is not budging. I used a block of wood to stop the blade from turning but the pliers still stripped on the nut. I'll keep using this one ( a 203A) with its noisy 1/2 blade until it completely dies.
