Dishwashers Logo
Posted on Jun 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an error code E24 on my new Bosch Silence Plus dishwasher........what does this mean?
Clive
Level 3:
  • Master 882 Answers
  • Posted on Oct 15, 2017
Clive
Master
Level 3:
Answers
882
Questions
30
Helped
219602
Points
3292
ERROR E24:
Faulty drain pump or blockage.
Drain pump, pump's wiring or control board fault.
Pump's electrical resistance is incorrect.
This could indicate a short, open circuit or water ingress.
Try unplugging 15 min or so.
This will 'hopefully' re-boot the electronics circuit 'brain'.
Failing that, try replace parts one-by-one, starting with drain-pump.
If you stop washer full of water, it creates a heavy load,possibly stalling the pump
I'm not 101% sure, but 'stalled pump' could be the E25 error code also mentioned in question.
Remove water by hand or whatever means you can.
If you have an Aquavac-type vaccuum cleaner this works.
Check your filters are clear of water.
Remove the impellor cover then try to turn pump impellor.
It should be able to turn easily.
If not, pump is stuck.
The impellor cover is a small plastic cover secured by a single screw, located at the bottom / side of the machine, usually at the back or left.
An 'impellor' is technical gobbledegook for a water 'propellor' or 'fan' to drive water by centrifugal force.
Technical terms designed to confuse people LOL. :)
All done?
Refit the cover and try the machine again.
Hope this helps,
Clive.
3 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Mar 31, 2010
SOURCE: bosch dishwasher lfestyle automatic runs for 1 min
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Anonymous
  • 608 Answers
  • Posted on Dec 09, 2010
SOURCE: I have a bosch dishwasher
Error code 24 for a bosch dishwasher is either a bad pump or a plugged drain or airgap. This is where your washer connects to the plumbing system. If you are under warranty have it fixed if not I would start by seeing if your system and make sure it isn't plugged first. After that it could be the pump has failed.
Hope this helps
Anonymous
  • Posted on Jan 26, 2011
SOURCE: What does the error code E01 for bosch dishwashers
my dishwasher e01cod show then turn off
Top Dishwashers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
