Heating & Cooling Logo
A
Anonymous Posted on Jun 17, 2011
We have a Heat Controller Central Air unit Model Number QUE 30- 1C and am trying to find a troubleshooting guide...Thanks
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
  • Posted on Jan 12, 2008
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
A
Anonymous
  • Posted on Jun 07, 2008
SOURCE: Central air unit wont turn on
check the fuses
Anonymous
  • 540 Answers
  • Posted on Sep 13, 2008
SOURCE: My goodman cple18-1c model central
Ths sounds like the outside unit or compressor is not kicking in, check for power to the unit at the breaker box, or at the bottom of the contacts!
Anonymous
  • 12 Answers
  • Posted on Jan 31, 2009
SOURCE: amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Anonymous
  • 8 Answers
  • Posted on Mar 13, 2009
SOURCE: no heat coming from central air unit when heat is turned on.
check t stat make sure its set up for you system some stats have to be set up for a heatpump or iits gas or electric heat
Top Heat Controller Heating & Cooling Experts
jdthefixer
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Heat Controller Heating and Cooling Expert? Answer questions, earn points and help others
