See? Ya need to listen to the baby. It told you it was low for days. Ok, I have to assume you have filled the oil bottle.But now the copier can't know that. We need to reset the error code.You will need to go into the SERVICE MODE in order to do this. In order to go into sevice mode you must press a few buttons. Locate the yellow CLEAR button located above the 9 key pad. Now locate the red STOP button at the bottom. Ok, press the Clear button for a moment and then press the numbers 1-0-7, then press the STOP button. So....CLEAR(release) 1(release) 0 (release) 7(release) then press and hold the RED STOP button for 5 seconds. The screen will change indicating you are in service mode. On the menu you will see tabs. Select COPIER. Now you will see a new screen that will have several tabs across the top.SP DIRECT should already be highlighted, if not touch it and highlite it. Now, use the keypad and press "5810" and then press the # sign. When you press the # sign the display should ask you if you want to EXECUTE. Press EXECUTE. Now unplug the copier. Wait a second or two and plug it back in. This should do it.Glad to help and please let fixya know I helped you. SPINAL
