Dymo LabelWriter Thermal Printer Logo
Posted on Jul 05, 2011
Using windows XP with Chrystal Reports, the label prints half of the bar code, stops for 15-25 seconds and then prints the rest of the barcode. The bar code is fine, but want to eliminate the delay.
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Nov 09, 2007
SOURCE: improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
Anonymous
  • 3614 Answers
  • Posted on Mar 01, 2008
SOURCE: DYMO Labelwriter 400 stops printing half way through
Be sure to set the type of paper you use, printer problem also occur if the type of paper is not set.
Anonymous
  • 1605 Answers
  • Posted on Dec 18, 2008
SOURCE: barcodes - removed from top of lable
right click onthe barcode adn select none in the popup
if this help you solved you problem, please give me a FIXYA rating.
thanks
Steve Archer
  • 148 Answers
  • Posted on Jan 04, 2009
SOURCE: Printing Bar Code Labels from Intermec 3400
here is the specific intermec syntax (stx(esc)E1(can)(data)(cr)(data)(cr)(etb)(etx)PRINT
You have to send this sequence with no spaces (use hex equivalent or control c etc)
You can call intermec product support or call Scan Source tech support and they will hep you
Best of Luck
Anonymous
  • 10 Answers
  • Posted on Feb 11, 2009
SOURCE: BAR CODE FONTS FOR LITTLE LABELS
Depends on what software you are using, but you can use any True Type Font for the human readable, and any propritry barcode font available as downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Top Dymo Office Equipment & Supplies Experts
jdthefixer
Arnie Burke
Arnie Burke
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
