The fuser uses an oil supply unit, which is changed separately from the fuser itself. The fuser oil supply unit (400549) is what is required.
You will find the manuals and other sueful details about this printer here.
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
SOURCE: how to refill oil Fuser at unit at Ricoh Aficio
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
