Baby Care Logo
Posted on Jan 19, 2018
My first years baby monitors only work sometimes. Other times there is an annoying noise. The red light is just lit up and then all four green ones light up, then just the red and then all four light up again. This goes on forever. I can't hear my baby over this. How do I fix this problem?
ADArtist
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 04, 2019
ADArtist
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
650
Points
There is something wrong with the monitor, It happened to me and if you email the company they will replace it for you,
5 Related Answers
Anonymous
  • 102 Answers
  • Posted on Feb 26, 2008
SOURCE: red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
Anonymous
  • Posted on Jul 17, 2008
SOURCE: monitor goes black 1 second after coming to full screen
Same problem here. Does anybody have an answer?
itscervo
  • 6 Answers
  • Posted on Aug 19, 2008
SOURCE: Phillips FTR9965 / 12s
The no signal message is there because the screen is waiting for a signal from the receiver, it then switches into protection mode (flashing red). The usual cause is a blown protection fuse inside the receiver.
Anonymous
  • 903 Answers
  • Posted on Oct 23, 2008
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Rodie
  • 629 Answers
  • Posted on Mar 16, 2009
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Top The First Years Baby Care Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a The First Years Baby Care Expert? Answer questions, earn points and help others
