Apple iPod touch Logo
Posted on Jul 18, 2011
How to enable a disable ipod touch - Apple iPod touch
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
744
Points
11
In order to enable your disabled iPod Touch, you'll have to completely reset it. Turn off the iPod Touch and when it turns back on the first thing to appear will be an Apple logo. Connect the iPod Touch to the computer it is paired with when this logo appears. Once it appears in iTunes, choose the "Restore" option and that will update the software and restore the iPod Touch.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jun 08, 2009
SOURCE: Disabled 8GB iPod touch, can't enter passcode
I KNOW WATCH U FIRST PRESS THE  OFF BUTON AND LET IT TURN OFF  THEN PRESS THE HOME BUTTON LET IT PRESSED THEN U PRESS THE OFF BUTOON AND TILL THE ITUNE LOGO WITH THE USB U LET GO  BUT UR IPOD HAS TO BE CONNECTED TO ITUNES
Anonymous
  • 233 Answers
  • Posted on Jul 03, 2009
SOURCE: im trying to enable my disabled ipod touch,how can
ipod touch disabled might be due to incorrect password attempt or something else.
use this link from apple:
http://support.apple.com/kb/HT1212
God Luck, if it fails, comment back
Gil D
Gil Domanillo
  • 217 Answers
  • Posted on Jul 25, 2009
SOURCE: MY IPOD TOUCH IS DISABLE I DONT KNOW HOW TO ENABLE
here's how to enable it.
1. Turn on your iPod (in my case it would only get as far as displaying the Apple logo
2. Hold the power and home buttons down (the iPod will power off after 10 seconds, but keep holding those buttons down)
3. After the iPod powers off, release the power button (but keep holding the home button down)
4. After a couple more seconds, you should hear that magical “ding dong” that means the iPod is coming back alive, and that Windows has detected it. You may even see a little “New hardware” popup in Windows. It is now safe to release the home button, and your iPod is in DFU mode.
5. Now iTunes will see it as a DFU’ed iPod and should ask you to automatically restore its firmware.
6. iTunes has to download the new firmware, and it takes a while, so go make a sandwich.
Anonymous
  • 24 Answers
  • Posted on Jul 29, 2009
SOURCE: ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
Anonymous
  • 52 Answers
  • Posted on Jan 11, 2010
SOURCE: how to enable an ipod touch that has been disabled
you need to put your ipod in recovery mode. then you plug in it in your computer, and restore it from itunes.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
woodzowl307
SmartAviator
SmartAviator
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
