SOURCE: Samsung split system air conditioner model as24bpa
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
SOURCE: i have samsung split type room air conditioner,
http://aircon.ru/pbc_download/files/f1215245089.pdf
check out this web site as it has your items manual. It may help you trouble shoot what's going on. There is a trouble shooting section.
Hope this helps.
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
SOURCE: Recently bought samsung multi split
doesnt sound like a gas problem. theres a vavle they opens and closes inside the unit that might be playing up either the vavle or the indoor pc board. did it ever cool ? might also be the vavle on the outside unit were not open with the alan keys so theres no gas going to them .
