SOURCE: GE Microwave jvm1651BB will not heat
He's probably refering to a magnatron stir kit, comes with a magnatron, HV rectifier and stir runs about 170.00 for the parts. most of these you have to remove the microwave from the wall and dissassmble from the back to get to the componets. Its a High voltage system and if you have no experience I would leave it to someone who does for saftey reasons
SOURCE: stuck on pause
Chances are you need a new keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
SOURCE: My LG microwave oven, purchased
If I were you, I would go back to Home Depot and complain about the response you are getting in dealing with LG. They may be able to get an RGA ( return goods authorization ) and send it out to their repair place. Home Depot owes you at least that much since they are the ones that sold it to you. Check with the manager of their appliance department first ! ( bigtime hint to follow: It has been my experience that you wil get the runaround from each and every one of these suppliers.. not just LG.. ALL of them.. some ae a little better than others but by enlarge, they all _____ <--you fill in the blank.. Good luck my friend.
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a
microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: Hi - I have the same problem as llofranco (posted
Generally shops charge about $75-90 to visit the home and $75-90 more to do the work. That rate is set by each shop.
I would note if there is any unusual noise or if is it louder or quieter than normal.
A loud buzz, hum, or groan is usually a
shorted high voltage rectifier diode, but a sound like gurgling into an
empty coffee mug is one symptom of a failed magnetron, and yet the mag can
be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
(even if the magnetron passes these
tests, it can still be bad. If you have high voltage and the diode is
good, assume the magnetron is bad)
If
you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
If it's under magnetron warranty, GE will
send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful
number here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
We're
