Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
I think proton instructions will work just fine for you.
Good luck and happy Boating
Following are the operator manual and user manual link. Try resetting the equipment
http://www.furunousa.com/Furuno/Doc/0/26CC7564VV44J35TM286B6CB80/18x4C%2019x4C%20%20GD1920C%20Operator%27s%20Guide.pdf
http://www.furunousa.com/Furuno/Doc/0/1P65284PEHC450R3LUMNMSANEE/1834C%20op%20man.pdf
Thanks
Proton
Selecting a presentation mode
1. If not displayed, press the HIDE/SHOW key to show the radar soft keys.
2. Press the RADAR DISPLY soft key to show the RADAR DISPLAY soft keys.
3. Press the MODE soft key. Each pressing of the key changes the presentation mode and
the presentation mode indication in the sequence of North-up, True Motion, Head-up,
and Course-up.
Function Indicator on display Soft key label
North-up N-UP NTH UP
True Motion TR-M TRUE M
Head-up H-UP HD UP
Course-up C-UP CSE UP
4. Press the RETURN soft key to finish.
Select the North up and you would be all set ....
Thanks
Proton
Capter 2.9 on the user manual , would give you more details on the same .
Do rate the solution as helpful or fixya.
Below are the steps to reset the radar.
Radar: Heading adjustment, timing adjustment, MBS level, tuning point, tuning indication
(short, medium, long), video level, dead sector, antenna height, STC curve, antenna type,
on time, tx time, Sounder: White marker, hue, signal level, TLL output, depth calibration,
range.
1. Press the MENU key to open the menu.
2. Press the SYSTEM CONFIGURATION soft key.
3. Press the SYSTEM SETUP soft key.
4. Press the TEST & CLEAR soft key.
5. Press the MEMORY CLEAR soft key.
MEMORY
CLEAR
EDIT
RETURN
DISPLAY UNIT NO
GPS SENSOR NO
NETWORK SOUNDER NO
Memory clear menu
6. Use the Trackball to choose the memory to clear.
7. Press the EDIT soft key.
8. Use the Trackball to select YES, then press the ENTER soft key. One of the following
displays appears depending on the selection made at step 6.
ALL SETTINGS EXCEPT
SNDR ARE RESET TO
DEFAULT. ARE YOU SURE?
YES ... PUSH ENTER KNOB
NO ... PUSH CLEAR KEY
BEGIN COLD START
TO CLEAR GPS
MEMORY. ARE YOU SURE?
SOUNDER WILL BE
SET TO DEFAULT.
ARE YOU SURE?
Display Unit Clear GPS Receiver Clear Network Sounder Clear
Windows for clearing memory
9. Push the ENTER knob to clear the memory selected.
10. Press the MENU key to close the menu.
11. Turn the power off and on again.
Have you checked the orientation transducer? or the signal cable ? also check the sychronization between the transducer and the main display
the heading on top of display seems to be accurate. no heading sensor alarm
The problem is solved. Somehow my antenna "type" was changed in the menu! We don't know how this happened. everything works ok now.
