Chamberlain KLIK1 Remote Control Logo
Posted on Jul 30, 2011
I need to program a new Chamberlain universal remote with a Chamberlain Electolift G5440B but don't see any dip switches nor a smart learn button. so, what do i do?
5 Related Answers
ktkodama
Kevin Kodama
  • 37 Answers
  • Posted on Jan 20, 2009
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Anonymous
  • 10865 Answers
  • Posted on May 19, 2009
SOURCE: i have a chamberlain 950-315cb
Here is the website which will provide you with all of the info you need on the chamberlain remote and door openers
http://www.liftmaster.com/consumerweb
Anonymous
  • 20 Answers
  • Posted on Aug 18, 2009
SOURCE: universal remote does not work
Posting your garage door model would help, but there may be a button close to the LED on the garage door opener that you have to depress to allow the two to pair up. Assuming that this is the similiar to my garage door control mechanism, if you have the dip switches set correctly you need to depress the button mentioned above and then depress one of the buttons on the remote.
Anonymous
  • 14 Answers
  • Posted on Mar 14, 2010
SOURCE: need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
  • Posted on May 27, 2010
SOURCE: Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
Top Chamberlain Televison & Video Experts
Arnie Burke
Arnie Burke
Anonymous
Level 1 Expert
Anonymous
Level 1 Expert
Are you a Chamberlain Televison and Video Expert? Answer questions, earn points and help others
