20 Most Recent Maax INFINITI HYDROMAX AIRPOOL II CORNER BATHTUB - 100055-012-W - White Questions & Answers
2answers
Maax infinity hot tub error code clfl dont have
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
5/20/2014 10:48:48 PM • Maax INFINITI... • Answered on May 20, 2014
0answers
0answers
I have a maax hydromax tub and the temp. control needs replaced where can i buy one
Not as easily done as you would expect. What is the Model number of the Control Box under the bathtub?We need to know that before we can match up the sensor for you.RodUS Parts Center888-521-6183
2/12/2013 4:12:39 PM • Maax INFINITI... • Answered on Feb 12, 2013
0answers
We have a MAAX hydromax
I will advice you check manualsonline.com or manualnguide.com to check for the manual you requested for.
10/20/2010 10:03:33 PM • Maax INFINITI... • Answered on Oct 20, 2010
0answers
Maax hydromax waterjets are weak
  • Clogged or dirty jets can restrict water flow.
  • MAAX Canada recommends using specialized piping cleaner or dishwasher powder to clean the whirlpool system
4/20/2025 12:42:24 PM • Maax Home • Answered on Apr 20, 2025
Do you have a cartridge for Maax 4343 Rainforest Shower?
Question edited for clarity. Duplicate question deleted. Refresh page to see your question. We don't supply physical goods, just information. Order direct from Maax.
Shower And Door Replacement Parts - Maax
Maax https://maax.com > services > replacement-parts You can now buy shower replacement parts for MAAX showers, doors and kits online. Shop Now. Find the replacement part you need. Missing: cartridge ‎ 4343
MAAX Canada https://maax.ca > services > replacement-parts You can now buy shower replacement parts for MAAX showers, doors and kits online. Shop Now. Find the replacement part you need. Missing: 4343 ‎' Show results with: 4343
MAAX Parts Online
MAAX https://parts.maax.com > zMAAX > public > PartsOnline ... SHOWER-FREESTYLENA.JPG?H=130&THN=1&W=130\",&#
7/20/2024 1:41:34 AM • Maax Home • Answered on Jul 20, 2024
To find a diverter volume cartridge for my maax shower
Hello again Madge. You made two posts for one question! Maax is a maker of shower doors and enclosures, they didn't make your shower controller. https://maax.com/pros-corner/tools-resources/videos-training The number you stated, is just a number that they allocated to the complete shower unit. It looks like Aker by Maax might be the shower control supplier. Try them. Having said that, nothing in Spares.
Replacement Parts for your shower and shower door
AKER by MAAX https://akerbymaax.com > services > replacement-parts Find replacement parts for AKER showers and shower doors. AKER products are also compatible with MAAX brand shower doors. Order replacement parts online ... ..
7/20/2024 1:34:07 AM • Maax Home • Answered on Jul 20, 2024
Operating manual for Maax Aerofeel tub
It may well be here; https://www.yumpu.com/en/document/view/31444481/download-technical-file-maax
6/23/2024 7:58:37 AM • Maax Home • Answered on Jun 23, 2024
2answers
Hello, I have a Rainforest#100145 curved Maax Shower Model: 4343) and was wondering if there is a new glass door kit with rollers. TY
What do you need besides the rollers? They are still available thru Maax.
4/17/2024 8:32:06 PM • Maax Home • Answered on Apr 17, 2024
Maax bathtub jet just hums but does not turn on.
This usually indicates the pump is seized or has an obstruction in the impeller. The humming sound is from the electric motor, if left on it will trip the circuit breaker
12/2/2019 9:28:07 PM • Maax Home • Answered on Dec 02, 2019
Access and remove whirlpool 10012138 motor
good luck, designers must have thought they would last forever
5/23/2019 4:37:02 PM • Maax Home • Answered on May 23, 2019
Rotten egg smell in bathroom closet?
I can't tell about your water supply from this posting. Is it possible you have iron or sulfur in your water that only shows up in the hot water? If so, you may not have drained the water heater often enough to prevent problems. Usually, draining it about every 6 months will do it. To drain the water heater, turn off the energy source (electricity or gas), turn off the inlet valve, and connect a water hose to the drain at the bottom of the tank. Open the drain ****. Some don't have handles and require a flat blade screwdriver to open them. Run the drain hose down the driveway so the hot water from the tank doesn't kill your lawn. By the time it reaches the street, it should be cooled off enough not to hurt anything. If it's been a while, you may want to weight down a trash bag at the end of the hose so the water and sediment coming out don't stain your concrete driveway. Let the water from the end of the hose dissipate over the trash bag. It takes about 30 minutes to drain a 40 gallon water heater. It goes faster to carefully open the overflow pop off valve to let air in while it's draining. When it's drained, close off the drain spigot, open the incoming water and when it is quiet again (full), turn the energy back on. You may have to relight the pilot or click the igniter until it flashes one time to let you know it's working. You should have hot water again in about 30 minutes. If the smell in the drain persists, some baking soda and vinegar flush will normally take care of that.
5/14/2019 1:12:24 PM • Maax Home • Answered on May 14, 2019
Maax INFINITI HYDROMAX AIRPOOL II CORNER BATHTUB - 100055-012-W - White Logo
14 questions posted
Top Maax Home Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Maax Home Expert? Answer questions, earn points and help others
View Most Popular
Maax Home
  • Maax Home
Most Popular Question
maax hydromax tub temp control needs
  • Home
