20 Most Recent Invicta Pro Diver 9321 Wrist Watch Questions & Answers
How do I shorten the mtal band on the Casio 4334.
Push the pin through, in the direction of the arrow. I used a thin paper clip and a pair of pliers. Poke it through by about 3mm and then grab it and pull it out.
9/27/2011 3:15:56 AM • Invicta Pro... • Answered on Sep 27, 2011
Trying to remove watch links
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
1/9/2010 11:33:47 PM • Invicta Pro... • Answered on Jan 09, 2010
How do i shorten a metal watch band i have a casio
Look for removable pins in the band to allow removing one link at a time until it fits ok.
12/6/2009 9:26:47 AM • Invicta Pro... • Answered on Dec 06, 2009
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
3/24/2009 2:04:01 AM • Invicta Pro... • Answered on Mar 24, 2009
Invicta watch has loud self winding
Sorry for your Rolex....
In any case you will not be able to to repair watch yourself as it takes skilled man and special tools to do the job.
It is NOT common that the winding rotor is making a noticeable noise, unless you bought second hand watch.
1st cause can be that the rotor fixing screw is loosened and the rotor is touching caseback whilst in move. Then you are the lucky one as the only thing to do is to tighten it properly.
2nd cause can be that the ball bearing is too worn, bridge screwws are loose, rotor axis worn and so on and so on. In this case you may need some part replacement and much more complicated work must be done. As the outcome it will take more time to repair and you will pay more money.
Regards
Arthur
12/17/2008 2:57:33 AM • Invicta Pro... • Answered on Dec 17, 2008
Invicta Pro Diver 48mm 40239 Watch.
Question edited for spelling of maker. Question moved from Computers. Take it to a local jeweler store. The buttons need cleaning and servicing will fix it being off centre. Have a new battery are the same time.
2/15/2023 5:33:10 AM • Invicta Diver... • Answered on Feb 15, 2023
How do I set the time on an Invicta Pro Diver watch?
Depending upon the movement, most pro divers have a *****-down crown for water tightness. First unscrew the *****-down crown. You can then pull the stem out one or two clicks. The first click permits you to set the date by turning the crown one way or the other. The second click should permit you to adjust the time. Then push the crown back in, hold it down and ***** it down 4 water resistance. Be gentle when manipulating the crown and stem!
4/18/2016 4:12:17 PM • Invicta Diver... • Answered on Apr 18, 2016
Every time i look at my brand new invicta drivers watch , it looks like cloudy, where is the nearest accredited repair shop here in the phils.
  1. Customer Service - Invicta
    invictawatch.com/customer-serviceThe Invicta Customer Service Team is here to help. ... If you are not completely satisfied with an online purchase from an Invicta Watch Company website, you ...
7/11/2015 2:49:04 AM • Invicta Diver... • Answered on Jul 11, 2015
How do you set an Invicta Pro Diver 12470 Watch?
Insulting answers. Respondents simply didn't RTFM, which is lame in all three dimensions - typically Invicta. This product has been out since 2011. Where is its pdf manual? ESPECIALLY this product, which is so different than most every other Invicta watch !!
1/27/2015 1:49:39 AM • Invicta Diver... • Answered on Jan 27, 2015
Invicta Pro Diver 9321 Wrist Watch Logo
10 questions posted
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
View Most Popular
Diver Invicta
  • Diver Invicta
Most Popular Question
shorten mtal band casio 4334
  • Watches
