20 Most Recent Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Questions & Answers
Just replaced carb new spark plug and new gas line. Will start and run for 2 minutes . When you press the throttle it dies and won't start again. Same problem I had before replacing carb.
Rick if you are sure it is fuel related issue, does sound like it may be running out of fuel. Check the fuel filter in the gas tank and replace, also check the fuel tank cap as the vent in it may be plugged,which will cause this issue. A similar issue to this, is when the muffler screen gets plugged with carbon on some models. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How To Replace Chainsaw Fuel Filter What to do if your chainsaw wont stay running Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer Chainsaw Repair Help
4/14/2016 8:02:12 PM • Poulan P3314 14"... • Answered on Apr 14, 2016
Where do the wires attach
to a switch or points
5/30/2015 5:37:16 PM • Poulan P3314 14"... • Answered on May 30, 2015
How or what is the choke hooked up ?
It should be connected to the carburetor by a link and or a spring.
9/29/2014 1:38:39 PM • Poulan P3314 14"... • Answered on Sep 29, 2014
Very difficult to pull starter rope why??
This could be a lot of things. IF the fuel mixture is not right then the wear on the engine is excessive. Take the spark plug out and see if it is easier to pull. IF it is then the compression is too high and this could be from timing. If neither or those work, the clutch might be bad.
6/22/2014 4:46:25 PM • Poulan P3314 14"... • Answered on Jun 22, 2014
What causes a polan chain saw to **** back when i pull the rope
Dorothyjack: It sounds as though your magneto has gone out of timing. Between the flywheel and the drive shaft there is a small square key that keeps the flywheel from slipping on the driveshaft. The spark coming from the magneto is not causing the spark plug to fire at the exact time it is supposed to. You will need to remove the side cover from the motor, and check to see if the slot in the flywheel and the slot in the driveshaft (where the square key fits) are aligned exactly. if those two slots are not aligned (even a little bit) the saw's engine timing is off. This is caused by the chain being stopped suddenly while you are cutting (for instance if the chain pops off of the chain bar. it will be necessary to remove the flywheel (using a flywheel puller) and replace the key. then reassemble the saw making sure the chain tension is correct and that the magneto to flywheel spacing is correct.
5/31/2014 4:48:59 PM • Poulan P3314 14"... • Answered on May 31, 2014
Once the gas trigger on the handle is pressed to
check the main jet for blockage
4/11/2014 6:32:20 AM • Poulan P3314 14"... • Answered on Apr 11, 2014
My chainsaw poulan p3314 will run fine for about
Sounds like the engine is overheating and seizing. Most of the time this is a cooling or oil problem. Check the cooling fan for debris. Make sure you use the right oil mix.
10/18/2013 7:47:44 AM • Poulan P3314 14"... • Answered on Oct 18, 2013
Fuel filler cap too tight
Put some oil in its boundary it will open.
8/29/2013 11:21:47 AM • Poulan P3314 14"... • Answered on Aug 29, 2013
The cord to my Poulin chainsaw is sticking
To traxtor06
Your problem sounds like a broken starter spring. If the spring is broken it will slip allowing the tension to be released and not fully retract the rope.
2/3/2013 9:38:12 PM • Poulan P3314 14"... • Answered on Feb 03, 2013
2answers
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
12/30/2012 9:34:20 PM • Poulan P3314 14"... • Answered on Dec 30, 2012
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
126 questions posted
Top Poulan Tools & Hardware - Others Experts
Axel Gringmuth
L Pfaff
L Pfaff
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Poulan Tools & Hardware - Others
Most Popular Question
just replaced carb new spark plug new
  • Tools & Hardware - Others
