20 Most Recent Karcher PSI Electric Pressure Washer Questions & Answers
Karcher pressure washer
most likely motor or pump overheated and seized or burnt out remove cover to the unit and test for motor operation
10/13/2019 4:45:34 PM • Karcher PSI... • Answered on Oct 13, 2019
2answers
I am looking for a workshop manual for karcher hds
hi could you post your email address and i can email you a full pdf file, also on the chassis of the machine there will be a silver sticker could do with all the numbers to find which modle it is regards
3/19/2019 7:39:59 PM • Karcher PSI... • Answered on Mar 19, 2019
2answers
I have a Kew Hobby 80. The output from the lance
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
4/23/2017 10:00:27 AM • Karcher PSI... • Answered on Apr 23, 2017
Water leaks from trigger wand replaced o ring
Dear Robertkoch,
These type of wands are throw away type. The water could be leaking from the hose with the wand. It could be leaking from the valve. That is the valve is not closing when trigger is not pulled. Myself even when a wand (gun) is serviceable...I do not find it worth it fixing it. The wise thing to do is buy a new one. But if you wish to experiment and drill the rivets...and by any chance you fix the problem...then good luck for you. If you decide to buy a new wand...buy exactly the same as you have, so maybe you might use a spare from the old one for the new one when the time arrises.
Regards,
Fulltech.
4/20/2015 9:46:57 PM • Karcher PSI... • Answered on Apr 20, 2015
2answers
I have a karcher kb9020 which pulses when idol any ideas why
The "manifold" as talked about above is also called the "Control head". For a picture of the very small cracks in the control head see here: Karcher Control Head cracks The video linked to below talks about the cracks in the control head at 7:00 through to 7:08. They guy incorrectly calls it the cylinder head in the video. How to FIX Karcher pressure washer If Karcher made the control head from an aluminium casting, or used a metal insert near the point of failure, their product range would be a LOT more reliable.
10/20/2014 8:36:53 PM • Karcher PSI... • Answered on Oct 20, 2014
2answers
Loss of pressure and milky white oil in piston casing
if the oil has water in it there is more then likely a seal problem and if there is a sight gauge on the oil reservoir it should be no more then half way
10/5/2014 11:43:03 AM • Karcher PSI... • Answered on Oct 05, 2014
Used 2 hours now nothing checked all fuses.
Check the power cord from the end where you plug it in all the way to where it wires into the switch and check the switch also! They are notorious for going out! Best of luck!
9/27/2014 7:40:18 PM • Karcher PSI... • Answered on Sep 27, 2014
0answers
0answers
2answers
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when t
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
6/20/2014 11:45:55 AM • Karcher PSI... • Answered on Jun 20, 2014
I have a karcher pressure
you will have to take the cover off & look for melted wires or a fuse.
if there is no fuse the capacitor may have been cooked.
it should be a white cylinder.if it has been damaged it will have burn marks and may be swollen.
replace the capacitor and it should start.
6/2/2014 8:39:15 PM • Karcher PSI... • Answered on Jun 02, 2014
Kacher machine K2.98
So when you are using the machine & keeping the trigger pulled open the machine builds up to pressure then knocks off all the time. If this is so the machine is not at fault & is doing what it is meant to do & protect its self from over pressuring & the fault is in the nozzles you are using. You need to check the nozzle size is correct for the machine & also airline the nozzle to clear of any dirt. Thanks qwashers
5/2/2014 7:01:28 AM • Karcher PSI... • Answered on May 02, 2014
0answers
Karcher PSI Electric Pressure Washer Logo
166 questions posted
Top Karcher Garden Experts
ray012965
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
karcher kb9020 pulses when idol any
  • Garden
