20 Most Recent Elkay Dayton Stainless Steel 25 In.x 21-1/4 In. Single Bowl Top Mount Kitch Questions & Answers
Kithen sink two handle hot water side leaking at base when water is running?
Put on some Teflon tape on the threads and then put the nut back in place . This is a cure for most all leaks. Remember to put about 1-2 revolutions of the tape in the direction you put the nut on. This keeps the tape from coming off when you put the nut on.
2/16/2013 5:56:25 PM • Elkay Dayton... • Answered on Feb 16, 2013
Manuel for I r installation
Try Googling or search for it online with the model number and name of sink. The brand name website would most likely have it.
9/1/2014 4:40:29 AM • Elkay Home • Answered on Sep 01, 2014
Water fountain elkay model # edfp17c
Feel the water coming out of it to determine if its the cold water side of the hot. More then likely you broke something and to determine what it is will require you to remove it. Home Depot has sink bolt removal tool that makes it much easier. After you find where the problem is then contact manufacture and usually they will send you free parts to fix or complete new one.
5/1/2014 2:38:41 PM • Elkay Home • Answered on May 01, 2014
3answers
Fireplace Downdraft. How to stop blow down in my chimney pot and gave fire better draw.
A terminal that spins will help you with your down draught problem .There others that will work as well . Local building suppiers will have this in stock . Not the big box stores .
8/12/2026 12:52:19 PM • Home • Answered on Aug 12, 2026
If the water is turned off on a power flush toilet mounted to the wall, will it flush if there is water in the tank?
get in a plumber and get rid of the tenants if you filled up the cistern and the pump was working it should flush as there would be water to pump if the pump was working
7/10/2026 12:52:41 PM • Home • Answered on Jul 10, 2026
4answers
I am having trouble removing
It sound like you are having a thought time with the baffle plate removal from your Ultimate Wood Heater! Here are a few steps you can try to help get that last bit out:
1. Check for Obstructions: Ensure there are no other components hindering the baffle plate’s movement, such as debris or residual ash.
2. Gentle Tilting: Carefully tilt the baffle plate forward while pulling it out. Sometimes changing the angle can help clear the lip.
3. Lubrication: If the plate is stuck, a little lubricant (like WD-40) on the edges might help it slide past the lip more easily.
4. Pry Carefully: Using a flat tool like a screwdriver, gently pry at the lip to create more space while you pull the plate out.
5. Check for Warping: Inspect the baffle plate for any warping that might be causing it to stick. A bit of bending might help it clear the opening.
6. Seek Help: If possible, have someone else assist you, as an extra pair of hands might make it easier to maneuver.
If these tips don't help, consider consulting the manufacturer's manual or contacting customer support for specific guidance related to your model!
7/10/2026 6:30:56 AM • Home • Answered on Jul 10, 2026
4answers
What do you do first in a bathroom remodel?
first of all you need to make a plain of where you want bath or shower, sink,toilet and any vanity cubbards,and radiators to be placed, then you need to make sure all walls are square (wich might mean plastering) floors are sound (no movement), and work out the cost before you start, all the best.
7/7/2026 1:08:57 PM • Home • Answered on Jul 07, 2026
2answers
ON MY JASON ELECTRIC BLANKET I HAVE FLASHING P WHAT DOES THAT INDICATE CAN I RESET OR DOES IT INDICATE THE BLANKE IS DAMAGED IN SOME WAY AND I SHOULD NO USE
That means the unit is not plugged in from the control to the blanket. If you have it connected, then the element in the blanket or one of the thermal safety features is open.
6/7/2026 10:13:05 PM • Home • Answered on Jun 07, 2026
4answers
Bathroom sink clogged up will not drain how do I unclog it
Bleach, caustic soda, sink plunger ... depends what clogged it.
6/2/2026 11:13:23 AM • Home • Answered on Jun 02, 2026
2answers
Which is best, Tiles or PVC panels for bathroom
Old question that just had spam removed which brings it back to view on the homepage.I expect you have already decided, but PVC Panels are fast to install and provide a good watertight seal over showers and baths. They are easy to clean and require little to no maintenance.Tiles are more durable and give you endless colour ways, sizes and styles. Some maintenance (grout cleaning) is required if they are in an environment that gets wet.https://www.google.com/search?q=Tiles+or+PVC+panels+for+bathroom..
5/11/2026 5:48:30 AM • Home • Answered on May 11, 2026
I made soup in my Seb pressure, but now I can't get the lid off. What do I do?
Light colors like white, beige, and soft pastels can make a small room look bigger by reflecting more light and creating an open feel. Avoid dark colors on all walls, as they can make the space feel smaller. ?? Learn more here:https://www.housebeautiful.com/room-decorating/bedrooms/g2231/small-bedroom-design-tips/
3/25/2026 6:45:41 AM • Home • Answered on Mar 25, 2026
11answers
How to Fix my house so it look more attractive to customers?
Selling a home is a huge step, involving various modifications, the search for an excellent real estate agent and finally managing to negotiate a reasonable price for your home. Aside from all that, you'll need to make a few more steps to make your house attractive to potential buyers and sell it quickly and at a high price.
  • Light it up
  • Don't show off pets
  • Hire a good real estate agent
  • Improve the exterior
  • Make the house show-ready
3/16/2026 1:20:42 PM • Home • Answered on Mar 16, 2026
Brand new atomic clock , I set everything and when it gets to the the year the day also changes but it is off by a day. Any suggestions?
Check your time zone and DST (Daylight Saving) settings-wrong settings can shift the date by one day. Also place the clock near a window and let it sync for 12-24 hours. If still wrong, reset it by removing and reinserting the batteries.
2/10/2026 12:28:07 PM • Home • Answered on Feb 10, 2026
3answers
Troubadour wood stove
Look up companies locally that can cut glass for CERAMIC glass only and get a rope gasket from a local stove company along with stove cement. Not the best solution and I can't guarantee it won't break again but that is the type of glass that would be utilized on a wood stove since the manufacturer is no longer in business. You can also search on the internet for replacement parts for that manufacturer. It would be aftermarket but at least it would be the whole door. Your other option is to replace the wood stove that takes the same size flue pipe as the Troubadour wood stove you have. Sorry not great answers but when these manufactures go under for a while its like trying to find parts for a studebaker. Sometimes you just have to make do.
12/9/2025 7:00:03 AM • Home • Answered on Dec 09, 2025
I have had a problem three times now with McDonalds ranch salad.I contacted the McDonalds that I bought one from and they gave me another with the same problem.
1-800-244-6227 this is the number to McDonalds Corporate, they should be able to help you
12/7/2025 8:34:01 PM • Home • Answered on Dec 07, 2025
Our Daniel Dakota mantel Clock Chimes 6 times at 3pm.
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
12/7/2025 8:27:25 PM • Home • Answered on Dec 07, 2025
3answers
Daniel Dakota Mantel Clock. It now Chimes 7 times at 8 O'clock. It is now doing my head in.
Old Question!! It was resurrected by an AI Answer.Remove the hands and set them to 7:00 at the instance it chimes 8:00.https://www.google.com/search?q=Daniel+Dakota+Mantel+Clock+It+Chimes+7+times+at+8+O%27clock..
9/22/2025 11:19:25 AM • Home • Answered on Sep 22, 2025
Toilet that keeps running
Check the flapper valve. It may have a gas bubble under the rubber flap, or it may need to be replaced.
7/23/2025 5:12:12 AM • Home • Answered on Jul 23, 2025
Elkay Dayton Stainless Steel 25 In.x 21-1/4 In. Single Bowl Top Mount Kitch Logo
1 questions posted
Top Elkay Home Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an Elkay Home Expert? Answer questions, earn points and help others
View Most Popular
Elkay Home
  • Elkay Home
Most Popular Question
kithen sink two handle hot water side
  • Home
