20 Most Recent Provo Craft Cricut Disney Font Cartridge Questions & Answers
3answers
My Cricut Expression keeps turning on and off.
I would contact cricut because you may have a defective machine. I had an expression and cut one thing then it froze. We did the reset and that did not resolve the issue. Cricut had me send my machine back and they shipped a new one. Mind you they will put a charge on your credit card only to protect themselves. You just ship yours to them the way they tell you in the one you receive. Let me know if you do not have their contact number.
9/5/2021 9:17:45 PM • Provo Craft... • Answered on Sep 05, 2021
Cricut mini flashing red light
1-Open Cricut Craft Room with circuit on and flashing green/red
2-Hold power & feed button together until both are solid green
3-You'll be prompted to update firmware
4-Press & hold two buttons again (keep holding)
5-initiate firmware update
6-Let sequence go until 99% ...you may hear a sequence of beeping, don't be alarmed
7-Release buttons
8-You'll be prompted to restart your machine
9-Unplug all plugs from Cricut
10-Wait 30 seconds
11-Plug in both cords
12-Power on Cricut
13-Light should be solid green
14-Press OK on Craftroom prompt on computer
15-Done
3/24/2016 1:49:00 AM • Provo Craft... • Answered on Mar 24, 2016
I can't my cricut to turn on
which machine are you using and what is it doing exactly?
11/10/2015 8:12:10 PM • Provo Craft... • Answered on Nov 10, 2015
I have a cricut and I can't get it to turn on. It's worked before.
what machine are you using ie expression or E2
11/10/2015 8:08:24 PM • Provo Craft... • Answered on Nov 10, 2015
2answers
Dials not working
You may want to try resetting your Cricut to see if that fixes the problem. To reset the Cricut machine, turn the unit off for five minutes. Roll all the dials all the way up and all the way down five times each. Turn the Cricut back on. This is the manufacturer's reset process. Good luck!
10/15/2015 2:36:55 AM • Provo Craft... • Answered on Oct 15, 2015
2answers
Jpeg file onto a cricut
Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
12/31/2014 10:36:00 AM • Provo Craft... • Answered on Dec 31, 2014
Side popped off Cuttle bug now no pressure
Mine has just done the same, have you found a solution?
11/21/2014 10:02:13 AM • Provo Craft... • Answered on Nov 21, 2014
I have just got my cricut, it won't cut, I have
Same here if you figure it out please let meknow..
4/16/2014 1:37:18 AM • Provo Craft... • Answered on Apr 16, 2014
I have the cricut, It has worked before now it
The same thing is happening with mine. I probably haven't used it over 12 times! It came on initially, then went off. It hasn't come on since! Don't look to get any help from Provo Craft, as you've probably already found out. I can't find any place that repairs them, but on eBay they sell refurbished ones...odd. So, someone knows how to repair them!
2/5/2014 6:27:11 PM • Provo Craft... • Answered on Feb 05, 2014
I can't get my cricut to cut out the whole letter.
I need more information. Are you using Cricut Design Studio or cutting just from the cricut itself. If you're cutting from Design Studio then you need to make sure your letter is within the space of the mat. If there is some hanging off the edge or past the cut line then it will skip over it and not cut it.
12/2/2013 9:32:26 PM • Provo Craft... • Answered on Dec 02, 2013
3answers
Brand new cricut doesn't turn on, just clicks with lights blinkin
Yes, I was just going to recommend contacting them. I see you have contacted them already. Good luck with getting it fixed~they are prompt in helping with machines. If you have any further questions about the cricut feel free to ask.
8/18/2012 8:15:23 PM • Provo Craft... • Answered on Aug 18, 2012
2answers
The cricut does not cut through the paper, it only
Yes, there are three rollers that one adjusts your size of the image you are cutting that is on the right hand side of the machine. The other two are on the left side of the machine. The top one is your speed control and the bottom is your pressure. I would move it up to medium when cutting with cardstock or even up to high if it is thick cardstock. Hope this helps, any further questions feel free to ask me.
10/17/2011 9:37:14 PM • Provo Craft... • Answered on Oct 17, 2011
3answers
WHen the cricut is cutting it tears my paper even
After having the Cricut for many years, I finally figured out how to cut the intricate cuts. Use multi cut 2, speed on med (3) and pressure on 4. I also keep my blade at 4. It takes a lot longer to cut but it cuts out good!
10/17/2011 9:35:36 PM • Provo Craft... • Answered on Oct 17, 2011
2answers
My cricut will turn on but the lcd screen is black
Sounds like you have a bad connection in there. I would contact Cricut for tech support; they will probably be able to send you another machine to replace yours. Mind you they will put a charge on your card and remove it when they receive your machine. I hope this helps if you need their contact number get back in touch with me.
6/13/2011 7:20:11 AM • Provo Craft... • Answered on Jun 13, 2011
2answers
How do I change a cricut machine blade
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
12/2/2010 12:00:14 AM • Provo Craft... • Answered on Dec 02, 2010
I find it very difficult
This may help: If your mat is too sticky, you need to prep your mat, sort of like "curring" your cast iron skillet when it is new. (I guess I just aged myself.)
Remove the clear plastic film from the mat. Pat both hands all over mat for several minutes. Next place a piece of cardstock (same size as mat) and remove, repeat 8-10 X. This should also reduce the "confetti" or leftover tiny paper pieces on messy mats.
Hope this helps!!
Dancing Bear
9/18/2010 1:50:45 AM • Provo Craft... • Answered on Sep 18, 2010
My cricut machine won't cut the paper
I am having the same problem...did you have any luck solving it?
6/8/2010 5:43:08 AM • Provo Craft... • Answered on Jun 08, 2010
Cricut personal blade appears to be dragging
Have you checked to make sure the blade is inserted all the way??
3/25/2010 1:54:51 PM • Provo Craft... • Answered on Mar 25, 2010
Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
3/25/2010 1:52:38 PM • Provo Craft... • Answered on Mar 25, 2010
LCD not working and not all buttons come on
I would contact Cricut as there is a way to reset your machine. Resetting your machine may fix the issue. If it continues after the reset Cricut may ask you to send the machine to them. They will however ship another to you after applying a charge to your card then removing the charge after you ship your machine with issues back to them.
3/25/2010 1:32:24 PM • Provo Craft... • Answered on Mar 25, 2010
Provo Craft Cricut Disney Font Cartridge Logo
Popular Tags
74 questions posted
Top Provo Craft Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Level 1 Expert
Anonymous
Level 1 Expert
Are you a Provo Craft Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Provo Craft Crafts & Hobbies
Most Popular Question
when cricut cutting tears paper even
  • Crafts & Hobbies
