20 Most Recent Simplicity Pioneer II SA200 Mechanical Sewing Machine Questions & Answers
I can't get the bottom thread to come up, got any
Try changing the needleTry rethreading the machine top and bobbinMake sure the bobbin is turned the correct way In the bobbin caseIt's possible that the machine needs to be checked for a timing problem
8/20/2013 1:02:55 PM • Simplicity... • Answered on Aug 20, 2013
Need manual
You may download a copy of the manual at http://dl.owneriq.net/9/9b8c90c5-c0f4-40e3-805a-58f386ebaeb7.pdf
8/19/2013 2:24:40 AM • Simplicity... • Answered on Aug 19, 2013
What size needle to I purchase
check with sewvacdoctor.coma1sewingmachines.com
12/12/2012 5:36:53 PM • Simplicity... • Answered on Dec 12, 2012
What size needle do I purchase for my simplicity Pioneer ll sewing machine
contact one of these sites and ask them, I checked on the internetand couldn't find anything about the machines needles, if it was me, I would try schmetz universal needles,that what I use in all my sewing machines, for cotton or flannel, but if I sew like stretch I would useball point, it depends on what fabric is being sewed what needles youuse,, but call or email these sites and ask them what they suggestsewvacdoctor.coma1sewingmachines.com
12/12/2012 5:36:15 PM • Simplicity... • Answered on Dec 12, 2012
2answers
The top thread continues to
I know you've said you have checked the tensions but that usually is the problem. When you pull on the top thread after it goes through the tension but before you thread it through the needle is there some tension but not so much that it breaks when you gently pull on it? It will be a bit harder to pull it at the point after it goes through the needle but it should have a bit of give there too without breaking.
Also check the bobbin again. Take it out of the machine and examine how the thread is wound around the bobbin. Is it all criss crossed or is it fairly evenly wound? Is it in the right direction and through the tension slot? Now dangle it by the thread while in the bobbin case. It should not just reel out to the floor but should slip a bit with some tension and hang there. A slight **** of the wrist should cause it to release a bit more thread and drop a bit more to the floor. It should allow slip but it shouldn't just reel out fast.
When you reinsert the bobbin case into the machine you should feel/hear a slight click as it catches into place.
Also check the needle though that usually isn't what causes this kind of problem.
The thread will break when it has no 'give'. Either the tensions aren't quite right or it is catching somewhere along the way through the various guides where you thread it. Oh and make sure the spool itself is freely turning on the spindle! Sometimes it is because of catching at that point and simply turning the spool upside down so it can't catch will solve the problem ! :)
1/19/2012 11:30:15 PM • Simplicity... • Answered on Jan 19, 2012
Do I need to oil
All sewing machines need regular maintenance and this includes using sewing machine oil (supplied with all Singer machines when new) where indicated by the user manual.
I can't supply you with a link though as it's not clear which model you have. Simplicity and Singer are different brands and you seem to have mistakenly mixed them up.
10/7/2010 1:24:51 PM • Simplicity... • Answered on Oct 07, 2010
2answers
Simplicity Fashion Pro SW2145 machine. When I sew a straight stitch the stitches are uneven and the top thread is loose. I have already tried to adjust the tension and bobbin tension, didn't help.
Question edited for clarity. It certainly sounds like a tension issue. Upper tension is too tight or the bobbin tension is too loose. As stated in the video, "tension is a delicate tug of war". Also, with the manual in front of you, do the machine threading again. The mind can play tricks. These are the best videos
3/18/2026 10:37:21 AM • Simplicity... • Answered on Mar 18, 2026
Simplicity Easy Lock EZ100 4 thread home Serger. What is the best way to get a printable manual for E-Z Lock Serger model EZ100 please?
Question edited for clarity, add magic word. Question moved from Misc category to Simplicity Sewing Machines, It is available on Scribd, but you have to register. There is a similar model in 'Blanks Outlet', and some offers on Pinterest. https://www.google.com/search?q=Simplicity+Easy+Lock+EZ100+manual ..
12/11/2024 10:38:54 PM • Simplicity... • Answered on Dec 11, 2024
2answers
I need a manual for the simplicity deluxe bias tape and piping machine.
Request the manual directly from Simplicity.
10/18/2024 7:12:46 PM • Simplicity... • Answered on Oct 18, 2024
How user-friendly is the operation of the wire nail making machine in Ghaziabad?
The user-friendliness of wire nail making machines in Ghaziabad can vary depending on the manufacturer and specific model. Generally, modern machines are designed to be user-friendly and include features such as:
1. Intuitive Controls: Many machines have user-friendly control panels that allow operators to easily adjust settings and monitor performance.
2. Automation: Advanced models often feature automated functions that reduce manual intervention, minimizing errors and boosting efficiency.
3. Safety Features: These machines are equipped with safety mechanisms to protect operators from accidents and injuries.
4. Maintenance: They are designed for easy maintenance and cleaning, ensuring smooth operation and long-lasting performance.
5. Training and Support: Reputable manufacturers offer training and support to help operators become familiar with the machine's operation and troubleshooting.
8/18/2024 10:06:20 AM • Simplicity... • Answered on Aug 18, 2024
Please - How do I change the 2 batteries in a Handicare Simplicity Plus stairlift. I cannot easily see the access to them.
There is not much on replacement. This is a UK stairlift, so this link might work better where you are. https://www.google.com/search?q=Handicare+Simplicity+Plus+stairlift+replace+batteries
Handicare 950 Straight Stairlift Replacement Batteries ...
Amazon.com https://www.amazon.com > Handicare-Replacement-Bei... Amazon.com: Handicare 950 Straight Stairlift Replacement Batteries Beiter DC Power : Health & Household. Rating: 4.6 · ‎11 reviews · ‎US$37.99 · ‎In stock Missing: Plus ‎' Show results with: Plus
INSTALLATION MANUAL - SImplIcIty
Anglian Lifts https://www.anglian-lifts.co.uk > 2021/06 > Simp... PDF If lift will not drive replace batteries and check charging circuit. code: meaning: 8 8. Up direction - Right hand. Down direction - Left hand. Description ...
How Long Do Stairlift Batteries Last?
Carelift Services https://careliftservices.co.uk > 2022/05/30 > how-long-... May 30, 2022 - Stairlift Battery Life : If you have a stairlift with a DC battery, then these will generally last around 2 to 5 years; depending on usage. Generic video
5/26/2024 1:11:34 AM • Simplicity... • Answered on May 26, 2024
2answers
Looking for a Free manual to print for a lite simplicity SL1000
No, I can't find a free one. In fact, it is hard to determine online just what company manufactured this machine as Singer, Brother and others have use the Simplicy name. But here is the sole manual I found and it is not free. https://www.sewingpartsonline.com/products/simplicity-sl1000-instruction-manual I see that ebay has a SL1200 for sale for under $50 but even it seems to lack a manual.
5/3/2024 3:51:15 PM • Simplicity... • Answered on May 03, 2024
Simplicity Model 1170 Sewing Machine. Trouble shooting list for the model 1170
Question edited for clarity, add maker, and 'what it is)'. Question moved to maker category. There are manuals here, but at a cost of $15. https://www.google.com/search?q=model+1170+sewing+machine+manual& Feed Dog Height adjustment, generic video https://www.youtube.com/watch?v=cSxW8i760Qc Adjust bobbin and upper tension ..
11/26/2023 10:07:06 PM • Simplicity... • Answered on Nov 26, 2023
Free manual to print for a Simplicity SL1000 Sewing Machine.
No Free ones for that model. $15.
Simplicity SL1000 Instruction Manual
Sewing Parts Online https://www.sewingpartsonline.com > simplicity-sl100... This instruction manual is the ultimate guide to unlock the full potential of your Simplicity SL1000. No more confusion or frustration-just clear, concise ... US$14.99 ..
10/14/2023 12:32:29 AM • Simplicity... • Answered on Oct 14, 2023
Simplicity Pioneer II SA200 Mechanical Sewing Machine Logo
Popular Tags
13 questions posted
Top Simplicity Sewing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Simplicity Sewing Machines
Most Popular Question
need manual
  • Sewing Machines
