20 Most Recent
Geneve 14K Diamond Cut Gold Face Watch for Women Questions & Answers
Need a new battery but
you should just contact the company directly
Geneva Watch Group
1407 Broadway
Suite 400
New York, NY 10018
Phone: 1-888-GWG-TIME begin_of_the_skype_highlighting 1-888-GWG-TIME
end_of_the_skype_highlighting
(888-494-8463 begin_of_the_skype_highlighting 888-494-8463 end_of_the_skype_highlighting)
Fax: 212-221-9414
or go to this link
http://www.genevawatchgroup.com/contact_form.shtml
They are the company that makes the watches. They can help you give you some address you might be able to mail or take your watch 2. good luck and best wishes.
Reset time on pocketwatch
Hi Tarynlarson,
Ok this can be done by GENTLY pulling out the crown till you hear or feel 2 clicks. Sometimes the crown has to unwound first, as you have not mentioned a specific model I am trying to be through.
Then you canjust rotate the crown and the hands should move and you can get it to the desired time.
When you have finished simply rescrew the crown back down.
Hope this helps?
Pocketwatch runs fast
Such a fast gaining usually is caused by dirty or magnetized hairspring, resulting in uneven coil amplitude (some of the coil rows are sticking together or touching each other). This causes the watch to run unbelievably fast.
To get the watch properly fixed you need to give to the watchmaker.
Alternetively; you can fix it yourself, but it will not last long.
For this you will need:
Case opener,
Dust blower (resin ball with nozzle),
Lighter fluid (ZIPPO),
Dropper (like one in eyedrops package).
Do as follows:
Open watch caseback,
Check for the fastest moving part in watch movement and you will see the hairspring fitted on it (pulsing outwards and inwards very fast).
Fill the VERY CLEAN dropper with lighter fluid.
Put ONE drop of lighter fluid on hairspring (DO NOT TOUCH IT),
Wait for a 10 seconds,
Dry out the lighter fluid with dust blower by vigorously squeezing it and pointing the nozzle on to hairspring from approx. 2-3 inches away.
Lay the watch on the table (dial down) and cover it with a clean, dustless cup. Leave for 15 minutes.
Fit the caseback on and enjoy your watch again.
Do not forget to rate, please.
My watch stop and it
Your watch needs to be clean,so that the old oil will be taken out,and change it with a new fresh oil.Old oil can caused the machine to stop,because old oil become sticky causing machine small gear stuck up and gear shafting can't move .
Hope it may help you;
Regards;
VOTIT
I have a dz09 smartwatch and when I go to connectivity it says empty. What am I suppose to do?
NIGHT FALL
Choosing the right watch depends on your lifestyle, budget, and decide the purpose-daily wear, formal occasions, sports, or smart features. Choose a comfortable size, a reliable movement (quartz for accuracy, automatic for tradition, smartwatch for tech), and durable materials like stainless steel with good water resistance. A good watch should match your routine, feel comfortable on your wrist, and suit your overall look .High end watch shop.
For more details explore our website:
https://dev-night-fall.pantheonsite.io/
4/28/2026 11:01:58 AM •
Watches
Answered
on Apr 28, 2026
I want to renew my
Renew by Mail if All of the Following are True:
Your Most Recent U.S. Passport:
Is undamaged and can be submitted with your application
- Was issued when you were age 16 or older
- Was issued within the last 15 years
- Was issued in your current name or you can legally document your name change
If any of the above statements do not apply to you, you must Apply in Person
A Note on the U.S. Passport Card:
If you are a previous passport book holder and you are eligible to use Form DS-82, you may apply for a passport card as a
renewal by mail - even if it is your first passport card!
How to Renew Your U.S. Passport by Mail:
From Inside the United States:
To renew your U.S. Passport by mail, you must submit Form DS-82, Application for a U.S. Passport by Mail. Locate Form DS-82 and step-by-step instructions at Form DS-82: Application for a U.S. Passport by Mail.
From Outside the United States:
U.S. citizens residing abroad (except those living in Canada) should renew their passports at the nearest U.S. Embassy or U.S. Consulate.
Need a U.S. Passport Immediately?You should make an appointment to be seen at a Regional Passport Agency only if:
- The U.S. passport is needed in less than 2 weeks for international travel
- The U.S. passport is needed within 4 weeks to obtain a foreign visa
Contact the National Passport Information Center to make an appointment or locate a Passport Agency.
Read more here: http://travel.state.gov/passport/renew/renew_833.html I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3/25/2026 12:20:03 PM •
Watches
Answered
on Mar 25, 2026
KADIO KD-3806 Model watch.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
1/21/2026 7:42:26 PM •
Watches
Answered
on Jan 21, 2026
Need directions for a Armitron 20-3454 7
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
10/21/2025 8:14:28 AM •
Watches
Answered
on Oct 21, 2025
How to set Harve Benard watch 20-093
General Steps for Analog Watches
- Pull the crown (the knob on the side) out gently to the first or second "click" position.
- First click: often to set date/day (if your watch has that).
- Second click: sets the time.
- Turn the crown to set the hour and minute hands to the correct time.
- Push the crown back in fully to restart the movement.
- If your watch has a date/day complication, after you push the crown in half-way (first click) you may turn to adjust the date/day, but avoid doing this around midnight (say between 9pm and 3am) since it may damage the mechanism.
According to generic quartz watch instructions:
"To set your watch's time... pull the crown fully out... gently turn the crown..." Manuals+
- If your watch is water-resistant with a screw-down crown, you may have to unscrew the crown first (turn counter-clockwise) before pulling it out. Then screw back in after setting.
?? Specific Tip from a User Guide for Your Model
I found a user question on FixYa for "How to set Harve Benard Watch 20-093". The advice given:
"Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears. Set the time: Use the ..." Fixya
This suggests your model might have digital/chronograph features (i.e., a "button on the top right" rather than only a crown). If so:
- Press and hold the top-right button until the display starts flashing (time-set mode).
- Then use other buttons (often the side bottom or top left) to cycle hours/minutes.
- Press again to confirm and exit.
? What to Check & Do
- Verify whether your watch has only a standard crown, or also buttons (top right / side) - this determines analog vs digital mode.
- If it's a digital display or hybrid (hands + digital), look for a mode button or "Set"-function via one of the buttons.
- Ensure the battery is fresh so the watch responds correctly when you try to set it.
- After setting the time, check for accuracy by matching it to a reliable clock
10/19/2025 6:39:45 PM •
Watches
Answered
on Oct 19, 2025
