Good day to you, I do not have the exact diagram in a document for you however I know you can find the manual for your unit over at cartpros. Here is a link for you:
https://www.cartpros.com/manuals/yamaha/g-series.html
Hope that helps you out :)
Verify series battery wiring. The main positive wire which goes to the solenoid should be on a positive battery post, that will be your main positive. Then from there we go series to all the rest of the batteries until we are left with a negative battery post, that will be your main negative. Make sure your charger wires are connected to the mains.
BuggiesGoneWild has all types of poems. Please visit their website.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Pleasecontact golf cart Kings out of Austin Texas. They will be more than glad to help you with this problem that you are encountering. Their Tek savvy is always free. Please be patient as so many people are always asking questions. But you can't beat free.
If a golf cart was working fine and suddenly will not move in either forward or reverse, the most common causes are low or disconnected batteries, a faulty forward/reverse switch, a bad seat safety switch, a blown fuse, or an issue with the key switch or solenoid. Even if the cart powers on, weak battery voltage or loose/corroded connections can stop it from driving. In many cases, the cart may also be in tow mode instead of run mode, or the controller may have temporarily shut down due to overheating. Checking the run/tow switch, battery voltage and cables, listening for a solenoid click, and inspecting the forward/reverse switch usually identifies the problem quickly.https://golfcartgears.com/
Ancient 12 year old question resurrected by an AI Bot.Question edited to make iGolf correct, Fixya capitalises the first letter. All question need full 'make model (what is is) first 3 words.Question moved from obscure 'Linear LLC / OSCO Linear / Osco Part Number 2520-238 CONTROLLER 115' category to Golf the game.Maker?https://www.google.com/search?q=igolf+softwareBushnell Watch Software?https://www.google.com/search?q=Igolf+msg+112..
Sometimes manually pushing the solenoid can cause it to get stuck in the wrong position. Check for that. Look for any loose or damaged wires connected to the solenoid. Use a multimeter to check if the solenoid is receiving power when you try to move the cart forward. If it's not, there might be an issue with the control circuit. Sometimes, simply resetting the cart's electrical system can resolve the issue. Disconnect the battery for a few minutes and then reconnect it.
Check the manual for additional troubleshooting steps.
Question edited for clarity and Translated to English.
English Only on Fixya please. We are a North American website.
Question moved from Misc to Golf Carts category.
IcoCar
https://icocar.eu > shuttle-62-3-0
The van has 8 seats and a powerful 6.8 HP brushless AC motor. The last row of seats can be converted into a loading area.
Missing: LITHIUM manual
IcoCar
https://icocar.eu > models
Shuttle 6+2 Lithium ... The new IcoCar CITY 3.0 CARGO EEC AC has an EU license plate. The e-car is also street-typed L6e / 30km/h.
Missing: manual ' Show results with: manual
CaddyTek
https://caddytek.com
Avid golfers everywhere are recommending Caddytek products for their durability, innovation and value. Caddytek push carts are designed for active golfers ...
Question edited for clarity.
Question moved from Computers and Internet. Magic word is 'Golf'
Yes according to this it takes a 24 volt Lithium battery. Fortunately putting a 12 volt battery in won't have damaged it where as 24 volts into a 12 volt system will.
Take it to your local golf retailer and they will know someone that can diagnose and repair the electronics.
I presume you checked the battery had a full charge.
The reviews on it are good
https://www.google.com/search?q=Bag+Boy+Navigator+Elite
Question moved from Cars and Trucks category.
It may have been corrupted update. Remove the App, reboot the phone and redownload the App. If that doesn't work, contact Golf Logix direct.
GolfLogixhttps://www.golflogix.com
The Complete Game Improvement App. From tee to green, GolfLogix provides the information you need to reduce strokes and play smarter.
