The generic cartridge may have damaged the printhead. This means either service or replacement. I suggest contacting Epson to see if they have any reduced prices on replacement units - I suggest the C88+
please power cycle your device (with a 30 second delay) and then check for the error again. If it occurs, then you would need to check the product manual troubleshooting section to identify the specific meaning of the error.
Thank you.
Paper jam problems can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam. The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.you can try following points.......1.turn off the machine for at least 5 minutes and disconnect the interface cable to the computer.2. push and hold down the "ink" button and the "paper" button and turn the printer on.3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.**You will need to try this several times to get the sequence correctly.If you need any kind of technical assistance, you can contact support cell at http://vtechsquad.com/printer-support/
Question edited for a lot more clarity, add magic word.Question moved from Misc to maker category.In my opinion, not a cost effective repair, the heads are expensive and sold out. You could risk an Ali Express knockoff.Epson - FA30032 - FA30022 - Replacement Printhead$902.00(Exc. VAT)Inc. VAT (UK customers only): $1,082.40https://www.google.com/search?q=epson+workforce+pro+wf-c878r+printhead+replacement..
Reddit · r/printers
6 comments · 2 months ago
With the demo key trial or TRIAL you should be able to reset the waste ink counter to 80% once. For a full reset you have to buy a one time reset key for like ...
2014 printer 10 years old. will those are problematic that od.
id you do the self test first. per the manual or manual direct print test page first?
comms are last ,
testing manually is first if that fails comms are useless.
can not run the cleaning cycle? i bet no.
3 led front of printer which 2 of 3 flash? blink
the book says power led flashes for 20 minutes after new ink. <<page 85
paper light false means paper jam or over opens stuck open (switches)
now this. same Page
The ink pads are near the end of their service life. Contact Epson forThe paper light and ink
light are flashing alternately support. (To continue printing, press the cancel button.)
as all printers like this do , at end of life, the 10 years of running ink cleaning steps
the wasted ink is put on to a (pad pit that soaks it up)
when that fails , end of life.
https://files.support.epson.com/docid/cpd4/cpd40326.pdf
free books. here.
Hold down the ink button for 3 seconds to start the cleaning cycle.
this step just above will fill up the ink waste pad in 10 years.
Epson
https://files.support.epson.com > pdf > dfx9k_ug
PDF
Problem. Solution. Error: Paper out. O Paper Out. O Pause. •••. No paper is loaded on the selected tractor. Load paper in the printer or select a different.
28 pages
JustAnswer
https://www.justanswer.com > printers > 8h3u8-epson-d...
May 29, 2014 - Customer: We have an Epson DFX 9000 printer. We are using 11 X 15 paper but the printer seems not to know that....our printouts are coming ...
1 answer · Top answer: Welcome, my name is XXXXX XXXXX I will assist you today! Before I suggest any changes or ...
JustAnswer
https://www.justanswer.com > printers > 727by-epson-d...
Aug 24, 2012 - We stuck a piece of paper in what we think it this cutout you mentioned but the printer will not run nor will hitting the pause button let it ...
1 answer · Top answer: Wendell Huneycutt : Hello, my name is XXXXX XXXXX I want to do everyt
old printers , just love to fail. all do.
for sure injet that love to clog it's nozzles 4,ink carts to fail.
tell what it does wrong first.
dead,
no color or streaks pages.
what?
does printer self test fail?
does printer self clean fail?
the free tech service manual is here. (a great FIND)
page 20 shows the error codes it can set
read page 27 on, for trouble shooting
https://www.manualslib.com/manual/749547/Epson-Stylus-C58.html#
good luck
page 19 clean heads mode
the manual is best downloaded to your PC first
the read as PDF
for best view and keep it forever
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
Follow the steps given below to reset Epson L382 printer.Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head.
Here are some steps you can try to troubleshoot and fix the issue:
Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
If the error persists after trying the above steps, you may need to replace the print head.
If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
