ASUS Computers & Internet • Uploaded on Oct 02, 2013
If they look like this, the mainboard is dead.Try to add a graphic card, in the graphic PCI-E socket on the mainboard, and connect the card to the screen, and see what happens.Make also sure, all your power connections are ok.Try also to download the manual, by selecting your windows system.Good luck
if you mean you dont have a vga driverWARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
if you are able to get a screen Click start control panel administrative tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If you computer came with a motherboard disk the drivers could be on it
or you might need to download them http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for
IE: motherboard name vga driver you might have to try a few times to get it right
hope this helps
109 questions posted
1,358 Questions
703 Questions
590 Questions
517 Questions
494 Questions
