20 Most Recent Konica Minolta bizhub 350 All-In-One Laser Printer Questions & Answers
Konica Minolta BizHub 363 error c-3823
This code has to do with fuser unit to not keep doing this over again. If the code comes back replace the fuser unit. re-setting over over could cause a fire that would ruin a perfectly good day. Once the new fuser is installed run this again. 1. Call the Service Mode to the screen. 2. Select the key as follows. [System 1] ? [Initialization] ? [System Error Clear]. 3. Press the Start key. 4. When [OK] is displayed, turn off the main power switch and turn it on again more than 10 seconds after.
7/9/2024 2:50:03 AM • Konica Minolta... • Answered on Jul 09, 2024
COMO REPARAR EL ERROR C3452 EN BIZHUB 350
Sir/Mam, On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens watch the left side of screen in the middle you will see a "." when that is displayed press 3. Enter the 8-digit service code and touch [END]. (Default value: 00000000) The code will come back but now press the Utility/Counter button, you should see a button that says Maintenance Mode press that, see Trouble Reset press that and the machine will again will go thru warm up procedure, you will see the "." DO Nothing! The machine should go to "Ready to Copy" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
7/9/2024 2:40:04 AM • Konica Minolta... • Answered on Jul 09, 2024
C2433 error
Not the correct model number BIZHUB 350. What is the correct model?
7/9/2024 2:36:00 AM • Konica Minolta... • Answered on Jul 09, 2024
Code erreur c-3823 konica minolta c550
If code comes back after conducting this procedure replace the fuser unit (The hot part) do not continue to reset machine it is broke and trying to tell you it is broke could cause a fire that will ruin a perfectly good day. Once fuser is replaced then re do the the procedure 1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
7/8/2024 7:38:43 PM • Konica Minolta... • Answered on Jul 08, 2024
Pcl xl error illegalmediatype
Incorrect paper tray setting change the to proper setting both on the machine and in the print driver
7/8/2024 7:20:11 PM • Konica Minolta... • Answered on Jul 08, 2024
I have Bizhub c350 IP 192.168.1.102 Subnet Mask
Check for activity on the copier where the network cable connects. Does your computer work ok on that network? move the copier to that connection
5/23/2024 5:47:47 PM • Konica Minolta... • Answered on May 23, 2024
C3451 bizhub 282
5/22/2024 5:50:38 PM • Konica Minolta... • Answered on May 22, 2024
C-3571 error
What model machine?
5/22/2024 5:23:11 PM • Konica Minolta... • Answered on May 22, 2024
SC46-08
An abnormal speed signal of the paper feed motor (M4) is checked. An error detection signal is detected twice in succession
12/24/2022 10:45:21 AM • Konica Minolta... • Answered on Dec 24, 2022
Ineo 350 c2557
Replace the black developer unit and black drum
10/25/2022 8:47:41 PM • Konica Minolta... • Answered on Oct 25, 2022
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
9/15/2022 7:23:47 PM • Konica Minolta... • Answered on Sep 15, 2022
How to find the MAC address for a konica minolta
I know this is and old post, but I came across this issue today and this post is the first that came up in my Google searches, and three was no good response. So I thought I would post an update.[Sorry Zaheer, I know you were trying to be helpful, but your response was a little too vague and in the end, inaccurate]1) Go to the printer's Web Connection by typing the IP address in a browser. 2) Make sure you are on the "System" tab (Blue) at the top3) Click on the "Detail" link on the side menu4) Click on the "Interface Info" sub link* Notice that you do NOT log into the Admin portion of the Web Connection. That will only confuse you.This will show various stats, one of which is the MAC Address of the machine. It seems like this would be better placed in the Network tab under the admin interface, but here it is.Hope this helps someone.
11/6/2021 6:16:57 PM • Konica Minolta... • Answered on Nov 06, 2021
2answers
Connect mac to Konica Minolta bizhub 350
7/2/2020 10:55:59 AM • Konica Minolta... • Answered on Jul 02, 2020
How to factory reset a bizhub 350
What are trying to reset ?????
4/4/2020 6:44:30 PM • Konica Minolta... • Answered on Apr 04, 2020
I have this code c024 in my bizhub c350. how can i
Did you mean C-0204???????? There is no C-024
4/3/2020 9:39:33 PM • Konica Minolta... • Answered on Apr 03, 2020
Konica minolta c350 error c0204
Tray 2 Feeder UP/Down abnormality. 2nd Tray Lift-up motor (M9) is problematic.
5/20/2019 12:51:24 PM • Konica Minolta... • Answered on May 20, 2019
Konica minolta bizhub 350 error 0x00000bc4
Agree as above.
4/28/2019 6:04:07 PM • Konica Minolta... • Answered on Apr 28, 2019
2557 error codes in C454e
developer abnormal
4/20/2019 4:12:25 AM • Konica Minolta... • Answered on Apr 20, 2019
Print a report
Pess utility printer setting print report and then print what you want
4/14/2019 9:04:43 AM • Konica Minolta... • Answered on Apr 14, 2019
How do I get my
First u need check your USB CABLE or USB connector is working or not
4/14/2019 6:30:49 AM • Konica Minolta... • Answered on Apr 14, 2019
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,100 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
c 0001 code konica minolta bizhub c350
  • Office Equipment & Supplies
